MiniDSP UMIK-1 Microphone - Home Theater Forum and Systems - HomeTheaterShack.com
 4Likes
post #1 of 887 Old 12-07-12, 04:04 PM Thread Starter
MiniDSP is a sponsor here at Home Theater Shack!
The UMIK-1 is an omni-directional USB measurement microphone providing Plug & Play acoustic measurement. From speaker & room acoustic measurement to recording, this microphone provides low noise and accurate results you can rely on. Forget about driver installation, OS compatibility and un-calibrated mics. The Umik-1 is a USB Audio class 1 device automatically recognized by all Operating Systems (Windows/Mac/Linux). It is provided with a unique calibration file based on the serial number. Time to finally focus on your measurements with three simple steps: Unpack, Plug, Measure!
No more mic preamp, no more phantom power, no more sound card calibrations... and USB Plug 'n' Play.
JohnM is currently working on a few tweaks to make using the UMIK-1 with REW a real convenience, however it can be used with REW as it is now.
See also: Using the UMIK-1 and REW with HDMI output
Cost is $75 and that includes the calibration file.
The following measurements show a comparison of the three mics I have on hand, the UMIK-1, IBF Akustik EMM-8 and the Behringer ECM8000.
These measurements are from a first use and quick setup of a Denon 4520 receiver that I am currently reviewing. It has been setup with Audyssey XT32, but not fully optimized for my HT room. I will get into more of that later with my review, but I wanted to at least get the mic comparison out of the way.
This is not a professional lab test my any means, although care was taken to do the best I could to get the mics equally aligned. There are no doubt some minor variances due to an imperfect test, but it is sufficient to show that the UMIK-1 is a worthy choice, especially taking into account the ease of use with REW.
All mic measurements were adjusted to align at 100Hz.
Here is a comparison between my IBF EMM-8 (calibrated in Germany) vs my ECM8000 (calibrated by Cross-Spectrum Labs):
Calibrated in two different parts of the world, I have to believe these are fairly accurate.
Next we add in the UMIK-1:
I also wanted to compare my external USB sound card that I have been using with the HDMI output on my laptop. Here is that comparison using the UMIK-1 mic:
Here are all three mics with the additional HDMI output measurement included:
I am of the opinion that if you have an HDMI output on your computer, purchasing nothing more than the UMIK-1 and HDMI cable makes for a very simple setup to use with REW. No external sound card is needed, no mic preamp, and no SPL meter is needed. Even if you do not have HDMI, the UMIK-1 is still a worthy consideration... and would be my choice of mics.
I did try the headphone output, but I could never get the controls set so that they were not effecting the output signal and could not get an accurate output measurement. The HDMI output was much simpler to work with anyway.
Sonnie is offline
post #2 of 887 Old 12-07-12, 05:03 PM
REW Author
JohnM's Avatar
John
Re: MiniDSP UMIK-1 Microphone
To use the UMIK-1 with REW (on Windows) in advance of the next REW beta (which will take care of all the following for you, along with some other things):
- Plug in the mic
- Start REW
- On the soundcard preferences make sure you are using the Java driver selection and select UMIK-1 as the input device and MICROPHONE as the input.
- On the Mic/meter preferences tab make sure you select "Mic or Z weighted SPL meter" as the input type and use the browse button to load the UMIK cal file.
- On the Analysis preferences make sure "Use loopback as timing reference" is not selected
The UMIK-1 can handle signal levels up to 130dB, but that means at normal measurement levels you will get warnings from REW about the input level being low. You can ignore those warnings.
The current version of REW cannot access the Capture volume control for USB mics, you can alter it manually if desired using the Windows recording volume mixer.
JohnM is offline
post #3 of 887 Old 12-07-12, 11:50 PM Thread Starter
Excellent John... do you have an estimated date for the next beta release of REW?
Sonnie is offline
post #4 of 887 Old 12-08-12, 03:02 PM
REW Author
JohnM's Avatar
John
Worst case it would be just before new year as I'm on holiday between Christmas and new year so I'll have time available, but I'm hoping to get it out before Christmas.
JohnM is offline
post #5 of 887 Old 12-10-12, 08:52 AM
John,
- Will there ever be a way ( & are you able to create a soft-patch within future releases of REW ) to use these new USB based microphones in conjunction with, REW's option to "Use loopback as a timing reference" ?
Thanks <> EarlK
EarlK is offline
post #6 of 887 Old 12-10-12, 09:13 AM Thread Starter
FYI... I ordered one of these and already have the tracking info for shipping and the calibration file was emailed to me for my serial number.
Sonnie is offline
post #7 of 887 Old 12-10-12, 09:37 AM
Dale Rasco's Avatar
Dale Rasco
I'll be interested in seeing how well they perform.
Dale Rasco
“Opportunity is missed by most people because it is dressed in overalls and looks like work." -Thomas A. Edison
Dale Rasco and
Dale Rasco is offline
post #8 of 887 Old 12-10-12, 10:43 AM
Wayne Myers
Another knockout calibrated mic offering. Wow, it used to take upwards of $300 for a factory calibrated mic plus an interface, now all you have to do is get out of one dinner date with the significant other, and you are set. Except for the fallout.
The timing loop back question is a good one. Perhaps MiniDSP can provide their converter delay time, add in "standard" USB buffering time, and have REW subtract those out automatically... Assuming no significant time variables. Just thinking out loud, certainly John already has a plan in mind.
shterling likes this.
AudiocRaver is offline
post #9 of 887 Old 12-11-12, 11:18 AM
Tim
So I have a Mac and am completely new to all of this, but I should be able to install REW, buy this mic and plug it in via USB and away I go? Is it easier to generate test tones via a tone generator CD (I use one of these now with an SPL meter) or should I use my Mac to do that which means I need to connect to my receiver/amp?
ack_bak is offline
post #10 of 887 Old 12-11-12, 12:41 PM
Alex
So I went to the post office today and picked up my UMIK-1. Apparently when miniDSP ships it to you they require a signature for delivery. Once I got home and started to unpack it, I must say I was sorely disappointed in what I saw. Not with the actual product, but with the care in which this product was packed. As you can see below there was nothing protecting the carrying case except a thin cardboard shell. Because of this my tab that is supposed to keep it shut was snapped off, the case was open a bit when I opened the box, it is cracked in multiple places, and the bottom is scuffed to no end. Definitely a much different experience than when I opened my calibrated Behringer mic.
As to the mic and accessories, I'm extremely happy with them. The mic has a nice weight to it and is fairly similar to the Behringer, albeit a bit smaller. The small stand is a nice touch and the USB cord feels substantial, if a bit short. I plugged the mic into my macbook pro and it was immediately recognized. Fired up REW and opened the MIDI audio controller and I was able to adjust the gain, add the cal file and it worked first time. There were zero issues, no drivers or software, and nothing else to do except calibrate the REW SPL meter with the new mic. Absolutely fantastic.
Philharmonic 3, Custom Center (Jordan Watts Module), Source Technology RC4/8.3, EMP E41B, Jeff Bagby Mandolin, CSS SDX10 Custom Sub (Baby Boomer), Custom LMS Ultra Dual Opposed, Custom 18" Pierce Audio Sub
fuzz092888 is offline
microphone , minidsp , umik1
