Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards
Rode NT1-A and m-audio questions
Discuss Rode NT1-A and m-audio questions in the Equalization | Calibration forum; Rode NT1-A and m-audio questions I am starting out with the subwoofer calibration "hobby," and have some basic questions. I have access to a rode ...
Views: 1943 - Replies: 2
Old 05-14-08, 01:17 AM   #1
Alias: David
Loc: Los Angeles, Ca
User: #20731
Since: May 2008
  htguy is offline
I am starting out with the subwoofer calibration "hobby," and have some basic questions. I have access to a rode NT1-A mic. My first question is can I use this mic for calibration? I also have access to an M-audio firewire solo. I want to use that unit or a similar one because I have mac computers (an ibook and an imac), and so I cannot install a sound card. My question is with the M-audio solo, do I also need to use a phantom power supply for the mic (either the rode, or that does not work I will probably get the Behrenger calibration mic that is recommended) or does the M-audio provide the power?
Thanks
Old 05-14-08, 01:29 AM   #2
SRR
Alias: Tim
User: #20375
Since: May 2008
  SRR is offline
Re: Rode NT1-A and m-audio questions
The NT1a being a large diameter condenser would not be a good way to go, get the Behringer ECM8000. And yes the firewire solo is all you need, as it provides phantom power for any condenser mic that needs it.
Old 05-14-08, 02:09 AM   #3
Alias: David
User: #20731
Since: May 2008
  htguy is offline
Thanks for the really fast, good reply.
« Home Theater Shack > Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards »
