Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards
digital RS meter
Discuss digital RS meter in the Equalization | Calibration forum; digital RS meter The more I read the more confused I get. There seems to be a little confusion as to which cal ...
Views: 552 - Replies: 1
Old 05-15-08, 08:39 PM   #1
Alias: chris
User: #20558
Since: May 2008
  hot grits is offline
digital RS meter
The more I read the more confused I get. There seems to be a little confusion as to which cal file to use for the RS 33-2055. I bought it about 2 months ago. Its QC# is 03A07. Should I be using the older analog file or the 2055 file? I really hope its the older one as my graphs look much better with it.
Old 05-16-08, 07:50 AM   #2
Alias: brucek
User: #6
  brucek is online now
Re: digital RS meter
The confusion wasn't about the digital meter (that you have), it was with respect to the newer analog meter Model 33-4050. There appeared to be a capsule change at one point.
Use the cal file specified for your meter....
« Home Theater Shack > Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards »
