| SPL Meters | Mic's | Calibration | Sound Cards Which SPL meter is worth buying?Discuss Which SPL meter is worth buying? in the Equalization | Calibration forum; Which SPL meter is worth buying? Of the choices we have for sound level meters which one deserves my money. The Galaxy CM-140 looks great.
But ... |
Views: 978 - Replies: 6
| Which SPL meter is worth buying? Of the choices we have for sound level meters which one deserves my money. The Galaxy CM-140 looks great. But wouldn't it perform just as well as a Radioshack SPL meter with a calibration file? It does cost about twice the Radioshack. What about this one? http://www.harborfreight.com/cpi/cta...emnumber=92282 It costs half as much and seems to be almost exactly the same as the old Radioshack meter. Which one is worth my hard earned money? | ||||
| | #2 | ||||
| Re: Which SPL meter is worth buying? The Radio Shack meter is not suitable for full range measurements. The Galaxy CM-140 is certainly your best bet. They're quite consistent between units. brucek | ||||
| | #4 | ||||
| Re: Which SPL meter is worth buying? No matter how you slice it the CM140 is an all around better db meter. It is a fair bit more accurate that even the digital RS meter. Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #5 | ||||
| Re: Which SPL meter is worth buying? It really depends on your intentions. I've been perfectly happy with my digital RS meter but I use it to check channel levels and some sub measurements. If you aren't using a receiver that has an auto-setup, an SPL meter is a must to get your channel levels adjusted correctly. IMO, if you have the funds buy the nicer one but if you don't the RS meter is a good compromise. | ||||
| | #6 | ||||
| Re: Which SPL meter is worth buying? Hi, Am a passive member of this site from some time ! I just visited back today and saw this post ! So what do you folks say about this meter ! http://larsondavis.com/Model831.htm Regards. | ||||
| | #7 | ||||
| Re: Which SPL meter is worth buying? Looks very expensive and a bit of overkill to make a simple room measurement for home theater. The Galaxy CM-140 is a reasonably priced SPL meter that we recommend. brucek | ||||
