Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards
Galaxy CM-140 range (Newbie Question)
Discuss Galaxy CM-140 range (Newbie Question) in the Equalization | Calibration forum; Galaxy CM-140 range (Newbie Question) Hi all, I have just ordered a PB13 Ultra. I expect I will have some REW and Behringer related questions ...
Views: 610 - Replies: 10
Old 07-28-08, 10:44 AM   #1
Alias: Graham
Loc: Cornwall
User: #23553
Since: Jul 2008
  Graham N is offline
Hi all,
I have just ordered a PB13 Ultra. I expect I will have some REW and Behringer related questions for you later.
For now my query is related to the Galaxy. There probably is an easy answer but it doesn't make sense to me as I have no idea how this all works apart from trying to follow idiot proof instructions.
The question is if your sub goes down to 15Hz or even less how is the Galaxy any good for taking measurements when it is rated as 31.5 Hz to 8kHz?
Thanks for the answer,
Graham
Old 07-28-08, 10:50 AM   #2
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Re: Galaxy CM-140 range (Newbie Question)
First of all, Welcome to the Shack Graham!
As with most SPL meters you use a calibration file to correct the readings this is available with REW and should be selected before running the test but also generally the measurements below 30Hz dont have much effect on your room response. The area that usually causes problems is in the 40 to 80 Hz range or just around the crossover frequency range.
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 07-28-08, 11:12 AM   #3
Alias: Graham
Loc: Cornwall
User: #23553
Since: Jul 2008
  Graham N is offline
tonyvdb wrote: View Post
Hi Tony,
thanks for the prompt reply.
Graham
Old 07-28-08, 01:16 PM   #4
Alias: brucek
User: #6
  brucek is offline
Take the time to read the REW HELP FILES and the REW Connection and Cabling Basics. It will help you a lot.
Old 07-28-08, 01:48 PM   #5
Alias: Graham
Loc: Cornwall
User: #23553
Since: Jul 2008
  Graham N is offline
brucek wrote: View Post
Thanks for the links brucek,
It all looks a bit beyond my capabilities to be honest, so it may be money wasted on all the equipment required. Also with regards to the choice of meter. On the links it shows the Radio Shack meters as being suitable but in the forums it seems to suggest that there is problems using these and the recommendation is to go for the Galaxy CM-140? I can get the RS ones easily here in the UK but not the Galaxy. (Not for reasonable money anyway (E-bay £103)).
My PB13 Ultra will be here tomorrow, with regards to the peq adjustment, do I need all this gear to be able to make adjustments using peq. In other words is there an idiots guide to setting up this sub without any extra gear?
thanks,
Graham
Old 07-28-08, 01:55 PM   #6
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
Graham N wrote: View Post
Welcome
Just get the RS meter ... if you'll use it to calibrate just the sub is fine
The problem with RS is that is not reliable above 3K-5K ... but for just the sub is fine, and cheaper too
Old 07-30-08, 06:11 AM   #7
Alias: jaspal
Loc: Stockholm
User: #23695
Since: Jul 2008
  jaspal kallar is offline
salvasol wrote: View Post
Welcome
I'm new here also. I'm in a similar position living in Europe (Sweden). I've only a 2 channel set up, no sub and the amplifier is integrated.
My speaker (kef 103/4) specs say:
Effective Frequency Range:
50Hz - 20kHz ± 2.5dB, -6dB at 38Hz measured at 2m on reference axis
Directional Characteristics:
Flat within 2dB from 50Hz - 17kHz up to 30º off reference axis in any direction
Okay, does this mean I can use the Radio shack SPL?
Cheers
jaspal
Old 07-30-08, 07:13 AM   #8
Alias: brucek
User: #6
  brucek is offline
Tell us what you plan to do with the Radio Shack meter... what is the goal?
Old 07-30-08, 11:55 AM   #9
Alias: jaspal
Loc: Stockholm
User: #23695
Since: Jul 2008
I have no room treatments in my room at the moment.
I want to find what modes are effecting my room so that I can better buy suitable acoustic room treatments accordingly. I want to know how much echo is effecting my room (that is a problem I already experience today).
After adding room acoustic treatments I would like to use REW again too check if the acoustic treatments have made any measurable difference, although I will use my ears as well
I don't intend on moving my speakers around. My living room is my hifi room.
Cheers
jaspal.
Old 07-30-08, 12:12 PM   #10
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Hi jaspal,
one really simple room treatment that makes a huge difference if you dont have carpet in the room is by placing a throw rug down on the floor this will absorb allot of reflection. I have even seen people put one on a wall and actually looks quite good.
Home theater:
Two Channel system:
My Webpage
Old 07-30-08, 02:13 PM   #11
Alias: jaspal
Loc: Stockholm
User: #23695
Since: Jul 2008
Hi jaspal,
tonyvdb, thanks for your tip. My floor is wooden (typical here in Sweden) and do infact have a large rug. I was thinking of putting a rug on the back wall as well... maybe later after I've done some measurements
cheers
jaspal
« Home Theater Shack > Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards »
(newbie, cm-140, galaxy, question), range
