Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards
ECM8000 w/ M-Audio MobilePre
Discuss ECM8000 w/ M-Audio MobilePre in the Equalization | Calibration forum; ECM8000 w/ M-Audio MobilePre Trying to pull together a setup to use REW. I am interested in full range testing rather than just sub ...
Views: 563 - Replies: 4
Old 08-18-08, 02:29 PM   #1
Alias: zippy
Loc: hampton va
User: #19936
Since: Apr 2008
  zippy is offline
Trying to pull together a setup to use REW. I am interested in full range testing rather than just sub optimization.
Based upon that, I am looking at the following:
ECM8000 microphone
M-Audio MobilePre
Will this work for the soundcard as well as the preamp and phantom power?
XLR cable
Mic Stand
I understand that I will need an SPL meter to establish a known SPL level. Will the RS meter be good for that?
Am I missing anything else?
Old 08-18-08, 03:20 PM   #2
Alias: brucek
User: #6
  brucek is offline
Re: ECM8000 w/ M-Audio MobilePre
Yep.............
Yep............
Cabling to your receiver from the soundcard. Cabling to create soundcard cal file............
Old 08-18-08, 04:06 PM   #3
Alias: zippy
Loc: hampton va
User: #19936
Since: Apr 2008
  zippy is offline
Thanks for the yeps!
Cabling to the receiver from the sound card. Doh! OK.
What cabling will I need to create the soundcard cal file?
Old 08-18-08, 07:13 PM   #4
Alias: brucek
User: #6
  brucek is offline
You would need a cable that was terminated in 1/4" TS phone plugs. You would connect from line-out to line-in and create a soundcard file and then remove that short.
Old 08-18-08, 10:36 PM   #5
Alias: zippy
Loc: hampton va
User: #19936
Since: Apr 2008
  zippy is offline
Thanks again!
« Home Theater Shack > Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards »
ecm8000, m-audio, mobilepre
