| SPL Meters | Mic's | Calibration | Sound Cards Recommended audio card?Discuss Recommended audio card? in the Equalization | Calibration forum; Recommended audio card? So I wasn't able to get REW going with my onboard audio card. And I'm also not entirely happy with ... |
Views: 710 - Replies: 10
| Recommended audio card? So I wasn't able to get REW going with my onboard audio card. And I'm also not entirely happy with it's sound. My other audio card is PCI based M-Audio Delta DiO 2496. I like it's sound, but it's a pain because you can't have wave & PCM output at the same time. So I'm in the market for a new audio card. Preferably under $100, sounds good, and is not a PAIN to set up in REW. ![]() Any suggestions? | ||||
| | #2 | |||||
| Re: Recommended audio card? Quote:
Does the card not work with REW? brucek | |||||
| | #3 | ||||
| Re: Recommended audio card? Bruce, I may have the terminology incorrect. The card can output practically anything it wants to. But not at the same time. For instance. I can be watching a DVD movie in 5.1. If I turn off the movie and start to play a game, I get no audio. I have to go into the control panel and change the audio type before I can hear simple WAVE sound. It's annoying to have to switch back and forth between settings all the time. M-Audio tech support says that is just how the card works, and suggested I upgrade to the Audiophile card. And no, I can't get the card to work with REW. But I'm new to REW and it could just be something I'm doing wrong. Regardless, due to the problem mentioned above, I'm ready to upgrade anyway. | ||||
| | #4 | ||||
| Re: Recommended audio card? If you just want something cheap, I just purchased the GWC 1500A at Newegg --> Works great! | ||||
| | #6 | |||||
This means I can turn on my computer and listen to youtube videos on my cheap computer speakers. Or I can listen to DD & DTS through my home theater system. All without touching a cable or any settings. ![]() | |||||
| | #7 | ||||
| Re: Recommended audio card? I'm also looking for a card since I've not been able to calibrate my E-MU 1616M card with REW. I've tried and tried, no can do. Ideally I'd like to be able to use my Apex 220 mic. with the card. Anyone recommend a card that will work EASILY with REW and a microphone? I really don't want to buy another card that I won't be able to calibrate. I apologise for hijacking the thread. ![]() | ||||
| | #8 | ||||
| Re: Recommended audio card? ^^^^^^ Does the Mic require Phantom voltage to operate? If so....I would look for something like the M-Audio Mobile Pre-USB... RayJr Home Theater Junky...on a budget | ||||
| | #9 | |||||
I already own a $500.00 (E-MU 1616M) soundcard with phantom power that I can't calibrate. I tried everything to get it to work but no success. I would be willing to buy another card with phantom power if someone has actually had success calibrating it.....or the other option is to buy an inexpensive card that works with the Radio Shack SPL meter since I own that too. Thanks again for your help. ![]() | |||||
| | #10 | ||||
| Re: Recommended audio card? The Mobile Pre USB will work ...I know I own one.....and it is up for sale...as I no longer have a use for it. Check the classified add...contact me if you would like any more info on it. RayJr Home Theater Junky...on a budget | ||||
| | #11 | ||||
| Re: Recommended audio card? Thanks everyone, for the suggestions. I wound up going with an M-Audio 192 card and have been mostly happy with it. It outputs 5.1 via digital output to my a/v receiver and also sends wave to my stereo receiver without me having to change anything. The only problem I've noticed is when I try to watch a recorded HDTV show, It will send a shrilling sound through my analog stereo output. So I have to make sure I turn off the stereo receiver whenever I listen to anything digital. | ||||
| Bookmarks |
| Tags |
| audio, card?, recommended |
| Thread Tools | |
