Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards
DEQ2496 phantom power for ECM8000?
Discuss DEQ2496 phantom power for ECM8000? in the Equalization | Calibration forum; DEQ2496 phantom power for ECM8000? I plan to use a DEQ2496 with an ECM8000. I have read the DEQ2496 manual, but cannot figure out if ...
Views: 652 - Replies: 1
Old 09-10-08, 02:24 PM   #1
Alias: TFan
Loc: Palo Alto, CA
User: #25111
Since: Sep 2008
  TheaterFan is offline
I plan to use a DEQ2496 with an ECM8000. I have read the DEQ2496 manual, but cannot figure out if the phantom power on the DEQ2496 allows output of the ECM8000 into my soundcard.
Do I still need to buy a mic preamp like the 802? It looks like it just works with DEQ2496.
I am using a SoundMax HS card in my laptop by Analog Devices.
Thanks.
Old 09-10-08, 02:55 PM   #2
Alias: brucek
User: #6
  brucek is online now
Re: DEQ2496 phantom power for ECM8000?
Correct..........
If you want to use the ECM8000 with REW, you require a microphone preamp or a soundcard with an integral mic preamp.
« Home Theater Shack > Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards »
deq2496, ecm8000?, phantom, power
