SPL Meters | Mic's | Calibration | Sound CardsDiscuss SPL Cal procedure on ECM8000 in the Equalization | Calibration forum; SPL Cal procedure on ECM8000 Hi guys, I used to use Radio Shack SPL meter in the test. Each time before I start the tests, ... |
Views: 795 - Replies: 15
| SPL Cal procedure on ECM8000 Hi guys, I used to use Radio Shack SPL meter in the test. Each time before I start the tests, I will do the SPL calibration as instructed. Recently, I retired my Radio Shack SPL meter and replaced it with the ECM8000. The new setup works pretty well, but how should I run the SPL calibration procedure (the cal file has been installed)? The mic itself does not show the SPL readings. How should I know that the MIC's reading is 75dB? Is the SPL readings shown in the REW the present SPL levels? M | ||||
| | #2 | |||||
| Re: SPL Cal procedure on ECM8000 Quote:
Then set the REW input level and run the Calibrate SPL routine and set to 75dBSPL. Now everything is calibrated. brucek | |||||
| | #3 | ||||
| Re: SPL Cal procedure on ECM8000 Thanks Brucek. How should I set the correct REW input level? Please let me know if below procedure is correct: I am using the 802+ECM8000. Set the mic trim and channel level on 802 to the middle position (as instructed in your old post). Adjust the main output on the 802 to read 75dBSPL on the REW SPL panel. The position of the main output volume control determines the REW input level. Max | ||||
| | #4 | |||||
1. The ECM and mixer and your receiver are all hooked up and ready to go, then the level at the listening position is set with your receiver volume control to 75dBSPL using the RS meter hand held with no connections. 2. The input level is set in REW to -12dB on the Input VU meter with the REW Input Volume control. 3. Run Calibrate and set to 75dBSPL. brucek | |||||
| | #5 | ||||
| Re: SPL Cal procedure on ECM8000 The "control output mixer/volume" and "control input mixer/volume" in my REW is grey and unable to select. How can I activate these functions? I am using the Creative SB-live! 24 bit external USB soundcard. | ||||
| | #6 | ||||
| Re: SPL Cal procedure on ECM8000 Select the card and the line-in and line-out port in the Settings screen Input and Output Device pull downs, then check the Control Input Mixer Volume box. Unless of course you're using Vista, then its selected in the Vista devices playback/record mixers. brucek | ||||
| | #7 | ||||
| Re: SPL Cal procedure on ECM8000 Got it. I just need to adjust the input volume control to let the SPL meter in the REW read 75dB, right? There is no need to adjust the SPL figure (a pops up window which starts with 75dB)? | ||||
| | #8 | |||||
The Input Volume setting is adjusted to get a proper level on the Input VU meter. Then the CALIBRATE routine is run. This generates a pink noise signal that we know will be 75DBSPL at the listening position because you already set it with the RS meter. Then while the test is running we adjust the thumbwheel to set 75dBSPL in the popup to match REW to that level. For convenience only, the default starting value in the popup is 75dBSPL. You may have set the value at your listening position to 76dBSPL, so you would adjust the popup to 76 at this time. brucek | |||||
| | #9 | ||||
| Re: SPL Cal procedure on ECM8000 Thanks Brucek. I finally know how to do this. The proper level on the Input VU meter is within 3dB, right? By the way, you said that the use of the RS meter should be limited to 3KHz. How about the ECM8000+802? Will the limit be extended to 10KHz? MAX | ||||
| | #10 | ||||||
brucek | ||||||
