| SPL Meters | Mic's | Calibration | Sound Cards MB 4000C for broadband sweep?Discuss MB 4000C for broadband sweep? in the Equalization | Calibration forum; MB 4000C for broadband sweep? OK, let me preface this by saying I have almost no idea what I'm doing. Any help would be appreciated.
Views: 317 - Replies: 2
| OK, let me preface this by saying I have almost no idea what I'm doing. Any help would be appreciated. I am trying to run some broadband REW tests using my SB 24 Live and REW. I borrowed this mic which I know fits the specs. The thing I don't know is whether or not it requires a preamp to operate. I bought an XLR-> mono 3.5 cable to hook it directly into the line-in of the soundcard. Because the mic is powered by a battery, it was my hope I didn't need the preamp. When I did some quick testing, I noticed that I had sound, but it was far too quiet to pick up test tones. I turned up the mic level as high as possible on the PC, and I could see it picked up something, but not nearly enough for a measurement. I'm wondering if someone can tell me what I need to make this work. My guess is a preamp, but then my question is - why is this mic any different than using the RS meter, which works fine without it? I'm also wondering if my issue is the fact that the 3.5mm side of the mic cable is mono, but I did set REW to the correct input (left) and it clearly picked up something there vs nothing on the right side. I have to wonder, however, if a stereo converter would fix my problems? I guess the last issue is that I don't have a calibration file...but I'm still hoping this would work for relative measurements (before/after shots for my treatments) even if its not a perfect representation. Thanks, Jeff | ||||
| | #2 | ||||
| Re: MB 4000C for broadband sweep? The microphone requires a preamp (with phantom power) to bring the voltage to a line level. A Radio Shack meter outputs line level and so is compatible with the line level inputs of the soundcards line-in port. Note, you cannot use a mic-in port of the soundcard with REW. The standard mic preamp use around here is the Hopefully, you have read and are completely familiar with REW Cabling Basics and the REW HELP files. brucek | ||||
| | #3 | ||||
| Re: MB 4000C for broadband sweep? Yup, I've read the guides and I knew about the Behringer. I was just hopeful this mic might have worked since it had an internal power source, similar to the RS meter. Thanks | ||||
