Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards
Which SPL meter for me??
Discuss Which SPL meter for me?? in the Equalization | Calibration forum; Which SPL meter for me?? I'd like to spend ~$100 or less on an spl meter and I'm wondering if there are any benefits to ...
Views: 982 - Replies: 33
Old 09-30-08, 10:28 AM   #1
Alias: Matt
Loc: Allentown, PA
User: #11567
Since: Sep 2007
  E-A-G-L-E-S is offline
I'd like to spend ~$100 or less on an spl meter and I'm wondering if there are any benefits to buying one other than the ratshack digital?
Trying to eQ five main speakers and run REW for my Tempest-X to help build a proper ported enclosure for it.
Old 09-30-08, 10:32 AM   #2
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Re: Which SPL meter for me??
The Galaxy 140 is better than the RS meter as the mic is more accurate particularly above 10K It can be found at Musicians friend for $99
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 09-30-08, 10:39 AM   #3
Alias: Matt
Loc: Allentown, PA
User: #11567
Since: Sep 2007
Hmmm....I just chcked there and it was listed as $129.
Is it more accurate below 10KHz?
I don't think I need to worry about ultra high-end accuracy as I have defined hearing loss up high.
But if it is more accurate from 20Hz-1KHz then it would be worth it?
Also, is the CM-130 junk or the same quality as the CM-140 just only able to go up to 130dB?(I don't think my system can go past 130dB)
Old 09-30-08, 10:41 AM   #4
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
its a little bit better as it goes slightly lower before dropping off.
I think Sonnie may still be able to get the deal for $99. I would PM him to see if its still available.
Home theater:
Two Channel system:
My Webpage
Old 09-30-08, 01:56 PM   #5
Alias: brucek
User: #6
  brucek is offline
is the CM-130 junk
Has no line-out port...... not usable with REW.
Old 09-30-08, 02:39 PM   #6
Alias: Matt
Loc: Allentown, PA
User: #11567
Since: Sep 2007
Thanks!
So rat shack or CM-130 it is.
Old 09-30-08, 02:48 PM   #7
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
E-A-G-L-E-S wrote: View Post
Thanks!
You mean CM 140, Right???
Old 09-30-08, 04:37 PM   #8
Alias: Matt
Loc: Allentown, PA
User: #11567
Since: Sep 2007
What do you guys think about using a Mic. instead of a meter?
I was told I could get a Mic. for $100 or less that would be more accurate than any meter that price and since I will be using REW that I should go that route?
Old 09-30-08, 05:14 PM   #9
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
I'm not 100% sure, but I think you still need a db meter as REW wont know what levels it is seeing without it.
Home theater:
Two Channel system:
My Webpage
Old 09-30-08, 07:03 PM   #10
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
Doesn’t matter, you still need an accurate reading up there. The problem with the RS meter is that it shows wonky response above 4-5 kHz or so that doesn’t in any way reflect what the speaker is actually doing. The CM140 seems to be a good “one-stop” device that will get your SPL readings for calibration and give good full-range readings as well.
Old 09-30-08, 07:25 PM   #11
Alias: Matt
Loc: Allentown, PA
User: #11567
Since: Sep 2007
Thanks Wayne!
The following is a quote from the same person who reccomended a mic over the RS meter....is he correct?:
"I have never used REW (I use TrueRTA) but if the software supports dB readings then all you need is a mic. That is all a dB meter really is, a mic and some software to give out readings. If you have a mic (an accurate one) and you have software that will interpret the mic signals, that is all you need."
Old 09-30-08, 08:28 PM   #12
Alias: Wayne
Loc: Katy, Texas
User: #8
...is he correct?
Probably, but the more important question is, do you have "software that will interpret the mic signals?" REW won't.
Old 09-30-08, 08:50 PM   #13
Alias: Matt
Loc: Allentown, PA
User: #11567
Since: Sep 2007
That was his question to me earlier and I could not answer it.
Thank you again Wayne and everyone!
So spl meter it is...is the radioshack one not good to use really at all?
I ask because Sonnie doesn't have that hook-up anymore and musiciansfriend has them for $129.(+shipping....so ~3x the cost)
Old 09-30-08, 08:58 PM   #14
Alias: Wayne
Loc: Katy, Texas
User: #8
Just keep in mind that for full-range measurements, it's cheaper than the combined RS meter, Behringer mixer and mic, and you'll feel better. Plus the CM140 will be quicker and easier to set up than all that other stuff.
Old 09-30-08, 09:24 PM   #15
Alias: Matt
Loc: Allentown, PA
User: #11567
Since: Sep 2007
Oh, one can't even use 'just' the RS meter, they need that other stuff as well with it?
Old 10-01-08, 08:06 AM   #16
Alias: brucek
User: #6
  brucek is offline
You have three possible choices. Take your pick.
1. Radio Shack SPL meter.
Suitable for subwoofers, and up to ~3KHz.
2. Galaxy CM-140 SPL meter.
Suitable for full range.
3. Microphone and SPL meter.
That's it.
Old 10-01-08, 10:22 AM   #17
Alias: Matt
Loc: Allentown, PA
User: #11567
Since: Sep 2007
Well, I don't know a ton about speaker calibration do and dont's, but can my AVR's Audyssey take care of my mains for now and I can use the RS to run REW so as to find out what design to go with for the ported box I want to build for it.(currently in a sealed cube for room test purposes)
Then I can sell the RS down the road for little and buy a CM-140 for my mains?(if needed)
Sound like a decent plan?
Old 10-01-08, 10:25 AM   #18
Alias: brucek
User: #6
  brucek is offline
Yep..
Old 10-01-08, 10:55 AM   #19
Alias: Matt
Loc: Allentown, PA
User: #11567
Since: Sep 2007
Thanks!!
Old 10-01-08, 05:18 PM   #20
Alias: Matt
Loc: Allentown, PA
User: #11567
Since: Sep 2007
After a few PM's telling me that the RS is a waste I was sent this, fro mthe same gentleman who was trying to help me before:
"Absolute SPL level doesn't matter for room measuring. All that matters is that REW's sweep is loud enough to be well above the ambient noise floor in the room. So use REW's "set levels" test (which plays pink noise), and make it fairly loud but not so loud it hurts"
......so he is urging I pass on the cheap dB meter and just use a mic? No idea what to do, lol.
Old 10-01-08, 05:39 PM   #21
Alias: Chris
Loc: Lincoln, NE, USA
User: #8712
Since: May 2007
  tenzip is offline
I personally would run to RatShack, buy the cheap analog meter, and use it. Blow off the high frequencies for now, just get the sub balanced with the mains. No, it's not a precision instrument, but it's plenty good for that purpose.
In the mean time, be on the watch for a sale/used mic and preamp, or, go get a mic and preamp when you can't stand it any more, and worry about the high end at that point.
I would say he's correct about the absolute level not mattering, but I think it's nice to know. Plus, I've used my meter in a few other places, like work. It's kind of a cool toy to have.
Old 10-03-08, 03:34 PM   #22
Alias: fbov
fbov's Avatar
Loc: Pittsford, NY
User: #24962
Since: Aug 2008
  fbov is offline
Matt.
As I see it (and I believe we have similar perspectives), the choice depends on your needs:
- the RS SPL meter will let you do basic LFE/sub EQ and room modes for $55 and some interconnects.
- The ECM 8000 + mixer will let you do that plus an awful lot more for only ~2x the price.
The question isn't how deep financially, but rather how deep technically you'll want to dive into this stuff. From my similarly-inexperienced perspective, complexity and ease of task completion favor the RS meter. If it's lack of accuracy above 550 Hz becomes a problem, it'll be a signal that I ought to upgrade.
It doesn't hurt that my local RS has one in stock ...
Have fun,
Frank
Old 10-03-08, 03:54 PM   #23
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
fbov wrote: View Post
I agree with you 100% ... if the RS meter is good to about 3KHz that's enough (to me at least)
BTW ... Welcome to the forum ... and don't forget to introduce yourself in the member Area
Old 10-03-08, 04:23 PM   #24
Alias: Matt
Loc: Allentown, PA
User: #11567
Since: Sep 2007
A member on that other forum was nice enough to send me his analog RS meter. Will be here tuesday.
Now I need to figure out how the to use REW.
Old 10-03-08, 04:28 PM   #25
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
A member on that other forum was nice enough to send me his analog RS meter. Will be here tuesday. Now I need to figure out how the to use REW.
That is nice ... Did he lend you or sell you the SPL???
You'll have good time with REW, it look intimidating at the beginning ... but after a couple of measurements you'll see
« Home Theater Shack > Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards »
me??, meter
