SPL Meters | Mic's | Calibration | Sound CardsDiscuss Connecting Mobilepre USB? in the Equalization | Calibration forum; Connecting Mobilepre USB? I searched but couldn't find a pic that shows how to connect the M-Audio's MobilepreUSB soundcard.. can anyone guide me ... |
Views: 634 - Replies: 1
| Connecting Mobilepre USB? I searched but couldn't find a pic that shows how to connect the M-Audio's MobilepreUSB soundcard.. can anyone guide me to one...? There are a few outputs on this card ..does it matter where I connect it to my AVR aux inputs? | ||||
| | #2 | ||||
| Re: Connecting Mobilepre USB? You want to connect the AVR to the same output you used to do the soundcard calibration... For soundcard calibration, you would need a cable that was terminated in 1/4" TS phone plugs. You would connect from line-out to line-in and create a soundcard file and then remove that short. Then use the 1/4" output with a TS plug to connect to the AVR. If you are using an SPL meter, use the 1/4" input with a TS plug. If you're using a mic, then you would of course use the XLR with phantom. All of this would be using only one channel of course. I believe they call them 1 and 2 instead of left and right, so use channel 2. brucek | ||||
