Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards
Hmmm, OK I'm stumped w/ initial REW run
Discuss Hmmm, OK I'm stumped w/ initial REW run in the Equalization | Calibration forum; Hmmm, OK I'm stumped w/ initial REW run I've installed everything and am running the initial loopback calibration file in REW. I connected a 3.5 to stereo adaptor ...
Views: 321 - Replies: 2
Old 10-21-08, 06:26 PM   #1
Alias: Travis
Loc: I ain't tellin ya!
User: #1166
Since: Jun 2006
  bass_addict is offline
I've installed everything and am running the initial loopback calibration file in REW. I connected a 3.5 to stereo adaptor to the line input and speaker output on the back of the SB live external SC (there is no mention of line out on the back of the SB so I assume you just use the main speaker out). I then looped the right channel together and also the left channel together, and ran the sweep. Doing this I cannot get the input within 3 db's of the output no matter what I do. If I unhook the line in and run it into the mic in on the front instead, I can get the input and output within a .1 db's of each other. It mentions the mic in is not suitable so what could I have hooked up wrong, and why would it work using the mic in?
Thanks
Old 10-21-08, 09:22 PM   #2
Alias: brucek
User: #6
  brucek is online now
Re: Hmmm, OK I'm stumped w/ initial REW run
You connect the front-out (right) to the line-in (right) only. That's it. Run the soundcard calibration routine.......
Old 10-22-08, 11:22 AM   #3
Alias: Travis
User: #1166
Since: Jun 2006
Thanks Bruce.
« Home Theater Shack > Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards »
hmmm, initial, stumped
