| SPL Meters | Mic's | Calibration | Sound Cards Behringer Xenyx 802Discuss Behringer Xenyx 802 in the Equalization | Calibration forum; Behringer Xenyx 802 Xenyx 802
Testing chain: External loopback (line-out - line-in)
Sampling mode: 24-bit, 96 kHz
Looped with EMU 0404 USB 1/4 ... |
Views: 1012 - Replies: 5
| Behringer Xenyx 802 Xenyx 802 Testing chain: External loopback (line-out - line-in) Sampling mode: 24-bit, 96 kHz Looped with EMU 0404 USB 1/4 TRS Input - RCA Output Frequency response ![]() Noise Level ![]() Dynamic range ![]() THD + Noise (at -3 dB FS) ![]() Intermodulation distortion ![]() Stereo crosstalk ![]() IMD (swept tones) ![]() ![]() Andrew | ||||
| | #2 | ||||
| Re: Behringer Xenyx 802 Xenyx 802 - Special Test Testing chain: External loopback (line-out - line-in) Sampling mode: 24-bit, 96 kHz Looped with EMU 0404 USB 1/4 TRS Input - RCA Output Frequency response - Infrasonic Extension ![]() Based on this the F3 is between 6-7Hz with the unit down about 1-2dB at 10Hz. Frequency response - High Frequency Extension ![]() Andrew | ||||
| | #3 | ||||
| Re: Behringer Xenyx 802 Andy, Can you expand your measurements beyond 20 and 20khz mainly for us crazies out there who try to get response below 10hz? Most modern day electronics are going to be fine between 20-20khz. I'm very interested in what happens at the extremes and I know others are too. My Xenyx 1202 measured very well atleast as far as the FR was concerned. Thanks.Last edited by Ricci; 10-24-08 at 03:48 PM.. | ||||
| | #4 | |||||
| Re: Behringer Xenyx 802 Quote:
Andrew | |||||
