| SPL Meters | Mic's | Calibration | Sound Cards Vista, Behringer UCA202 set-up?Discuss Vista, Behringer UCA202 set-up? in the Equalization | Calibration forum; Vista, Behringer UCA202 set-up? I am trying to get REW set up on my vista laptop. I tried my older Sound Blaster USB card ... |
Views: 1022 - Replies: 6
| Vista, Behringer UCA202 set-up? I am trying to get REW set up on my vista laptop. I tried my older Sound Blaster USB card and couldn't get a smooth response. When I plugged the output from the soundcard into an AVR, I noticed a lot of 'pop's and crackles as the sweeps played. Thinking I must have a bad card, I went and got a Behringer UCA202 as has been reported to work with Vista. I have not been able to plug this one into an AVR yet, but so far the measurements look the same as the sound blaster. I have tried changed the levels and making sure that every other audio control on my laptop is disabled. Same thing. I can adjust levels but my measurements always have these 'pop' in them. I have tried another USB port and the same issue. Java is up to date at version 6-10. ANy ideas? ![]() | ||||
| | #2 | |||||
| Re: Vista, Behringer UCA202 set-up? Quote:
Don't bother with anything else until you have a proper soundcard calibration completed and tested. When doing the soundcard cal routine, attempt a few different sweep levels i.e. up to -6dBSPL. Can you post a pic of your REW settings page. (you may need to go to the post padding thread and burn up 5 post before you can post pics) brucek | |||||
| | #3 | ||||||
| Re: Vista, Behringer UCA202 set-up? Thank you for the help. I forgot to add that I did have the wireless off when I was testing. Quote:
Was the image from my last post visible? | ||||||
| | #4 | |||||
| | #5 | |||||
brucek | |||||
| | #6 | ||||
| Re: Vista, Behringer UCA202 set-up? At first, I only had the one channel hooked up in loop-back mode. i noticed that the graph looked like popping, and it was never in the same place twice. After that, I tried running the cal test with the output from the soundcard running into an AVR. This is when I could clearly hear the crackle and pop on the sweeps. I have poked around and it seems that vista has been having some problems of this type. I just flashed the bios on my laptop and updated all of my drivers. I did find Thanks again for the help, Jason | ||||
