| SPL Meters | Mic's | Calibration | Sound Cards Phonic PAA3Discuss Phonic PAA3 in the Equalization | Calibration forum; Phonic PAA3 Well, I'm writing this post because someone told me that he adjusted his HT system using a PAA3 from Phonic.
Views: 366 - Replies: 8
| Phonic PAA3 Well, I'm writing this post because someone told me that he adjusted his HT system using a PAA3 from Phonic. ![]() He had an Onkyo TX-SR705 and did the Audyssey test. But to "time align" the subwoofer in an easy way without microphones and cards and stuff, he sitted in his sweet point and play a pink noise CD. Only the FR, FL and subwoofer were played. In the screen of the PAA3 he saw the frecuency response at that point. He moved the phase control of the subwoofer until in the crossover frecuency a +3 or +6 db increase appeared. What do you think of this "way" of subwoofer calibration? ![]() | ||||
| | #2 | |||||
| Re: Phonic PAA3 Quote:
But why use a $400 spectrum analyzser when REW offers one for free? brucek | |||||
| | #3 | ||||
| Re: Phonic PAA3 Because someone lends you one of those? jajaja ![]() thanks for the answer!! When the game ends, the king and the pawn return to the same box. | ||||
| | #4 | ||||
| Re: Phonic PAA3 Plus, the PAA3 is only 1/3-octave, while REW is 1/24-octave... Regards, Wayne | ||||
| | #5 | |||||
| | #6 | ||||
| Re: Phonic PAA3 By "one" do you mean the PAA3? Regards, Wayne | ||||
| | #7 | ||||
| Re: Phonic PAA3 Yes I mean the PAA3. I thought 1/3 octive was primarily not suitable for home theater use. The option is also in REW to use 1/3, so it must be used well for something? | ||||
| | #8 | ||||
| Re: Phonic PAA3 The PAA3 was designed as a portable device for measuring and tuning pro-audio sound systems - i.e., systems in auditoriums. In large rooms such as this, 1/3-octave is the defacto standard (unless that's changed since I left the biz a good number of years ago). Which is perfectly fine, because there are no modes in large rooms like those. In domestic systems, 1/3-octave would be suitable for full-range measurements (i.e., above the subwoofer frequencies). Regards, Wayne | ||||
| | #9 | ||||
| Re: Phonic PAA3 I see. I was using 65536-point 1/48 octave RTA using Flat-Top window and 2 averages since I was not using Pink PN. I will try and use the 1/3 octave setting with the mains and see if I can get better results. For some reason I get better results with the White PN in the RTA than the Pink PN, but I see this is for the Spectrum analyser. I'm not sure I understand why using the spectrum is for the White noise, but I will try that also. Thanks Wayne. | ||||
