SPL Meters | Mic's | Calibration | Sound CardsDiscuss Difference between A and C graphs in the Equalization | Calibration forum; Difference between A and C graphs When do you have to use C weighting and when A weighting? I now that this graphs show the ears ... |
Views: 500 - Replies: 2
| When do you have to use C weighting and when A weighting? ![]() I now that this graphs show the ears behavior under different SPL levels. So, what's the main difference in use between this two? ![]() Thanks!! ![]() When the game ends, the king and the pawn return to the same box. | ||||
| | #2 | |||||
| Re: Difference between A and C graphs Quote:
brucek | |||||
| | #3 | ||||
| Re: Difference between A and C graphs A-weighting rolls off response below 1000 Hz. That is, it filters off or removes bass frequencies from what registers on the meter. A-weighting is commonly used in industrial settings, as the upper frequencies more readily contribute to hearing loss. C-weighting adds bass frequencies to what the meter registers, down to ~40 Hz, at which point it begins to roll off. In a typical sound system, particularly a domestic one, that subjectively has linear frequency response, bass levels tend to be higher than the mid and upper frequencies. As such, switching the meter from A to C will result in a higher SPL reading. ![]() Hope this helps. Regards, Wayne | ||||
