Exodus Audio - Home of the infamous drivers using the XBL^2 motor technology!
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards
Galaxy CM-150 = Monarch 322?
Discuss Galaxy CM-150 = Monarch 322? in the Equalization | Calibration forum; Galaxy CM-150 = Monarch 322? Great forum you've got here, lots of good info. I have a Monarch 322 SPL meter: (I tried posting a ...
Old 11-21-08, 02:01 PM   #1
New Member
Alias: jtgray10
User: #29021
Since: Nov 2008
  jtgray10 is offline
(I tried posting a link but I guess I'm too NOOB to be allowed?? first result if you google "monarch 322")
which looks identical to the Galaxy 150 and has the same specs.
Is it safe to assume I can use the same .cal file?
Also, is there a way to tell if the 1/8" plug cables I have are mono or stereo?
Thanks a bunch
Old 11-21-08, 03:16 PM   #2
Alias: brucek
User: #6
  brucek is online now
Re: Galaxy CM-150 = Monarch 322?
It doesn't really match exactly.
And, even if it did, you have no way of knowing what capsule they actually used.
I wouldn't use the cal file for the CM, because you simply don't know if it's the same.
Old 11-21-08, 04:16 PM   #3
Friend of the Shack
Alias: Otto
Otto's Avatar
Loc: Beautiful Colorado
User: #625
  Otto is offline
jtgray10 wrote: View Post
If the plugs on the cables have three silver (metal) segments separated by two black rings, they are stereo. If there are only two silver segments separated by one black ring, they are mono.
-- Otto
« Home Theater Shack > Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards »
322?, cm-150, galaxy, monarch
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314
