Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards
Mic Pre-Amp Options
Discuss Mic Pre-Amp Options in the Equalization | Calibration forum; Mic Pre-Amp Options I'm thinking about upgrading to a Behringer ECM8000 Microphone for the REW software. Are there other pre-amp options to the ...
Views: 496 - Replies: 4
Old 12-01-08, 04:19 PM   #1
Alias: Anthony
Loc: Michigan
User: #23938
Since: Aug 2008
  MichiganMan is offline
Mic Pre-Amp Options
Are there other pre-amp options to the XENYX 502, 802 mixer boards?
Old 12-01-08, 05:07 PM   #2
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Re: Mic Pre-Amp Options
There is the TAPCO Mix50
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 12-01-08, 06:39 PM   #3
Alias: Anthony
Loc: Michigan
User: #23938
Since: Aug 2008
Is there something simpler?
I'm not familiar with mic equipment. It just seem strange there isn't a simpler way to power the mic and patch in the signal.
Old 12-01-08, 07:10 PM   #4
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Not for less than $45, The lower priced mixers do not have XLR inputs so they cant be used and you need to have some sort of level control.
Home theater:
Two Channel system:
My Webpage
Old 12-30-08, 08:40 AM   #5
Alias: Fred
audionut71's Avatar
User: #31071
Since: Dec 2008
  audionut71 is offline
I use the Rolls MP13 for my TrueRTA setup and the Behringer Mic. Simple, easy to use, and has phantom power. I did not want to carry around a mixing board just to have a powered mic input.
http://pro-audio.musiciansfriend.com...amp?sku=428714
I have seen it cheaper, just wanted to put up a link so you could see it easily.
« Home Theater Shack > Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards »
options, pre-amp
