Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards
Binaural Mics used for REW? am i making a mistake?
Discuss Binaural Mics used for REW? am i making a mistake? in the Equalization | Calibration forum; Binaural Mics used for REW? am i making a mistake? Hey all, I just started with REW, and so far so good! I'm using a portable mic setup I used ...
Views: 362 - Replies: 10
Old 12-01-08, 07:07 PM   #1
Alias: overmedium
Loc: nyc
User: #29524
Since: Nov 2008
  overmedium is offline
Hey all,
I just started with REW, and so far so good! I'm using a portable mic setup I used for ambient field recordings: sound-professional in-ear binaural mics that I run thru a core audio portable a/d converter (Core Sound Mic2496) to run into my mac and am able to get room readings, etc.
Do you think this will be alright to use for calibrate the system, or should i step up and buy a regular mic?
thanks in advance, rams
Old 12-02-08, 07:09 AM   #2
Alias: brucek
User: #6
  brucek is online now
Re: Binaural Mics used for REW? am i making a mistake?
REW accepts a mono line-in signal. The binaural mic outputs a stereo signal on a stereo plug, so you would only receive one of the channels into REW. You would also require a calibration file in REW.
Old 12-04-08, 10:26 AM   #3
Alias: overmedium
Loc: nyc
User: #29524
Since: Nov 2008
Okay, thanks brucek. I've been able to get readings so far without too much difficulty with the binaural mics.
Old 12-04-08, 11:05 AM   #4
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is online now
overmedium wrote: View Post
Without the proper calibration file for that particular mic you will not get accurate readings and thus rendering your final graph useless. Right now the only calibration files we have available is for the Galaxy CM140 SPL, Radio Shack SPL, and the ECM8000 mic. Available here
A calibration file can be made but you would require the detailed specifications of the mic your using including frequency response.
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 12-04-08, 11:17 AM   #5
Alias: overmedium
Loc: nyc
User: #29524
Since: Nov 2008
tonyvdb:
thanks for clearing that up. Did i miss this rather crucial detail when i read the tutorial guide (getting started with REW, calibrating soundcard, check levels, etc)?
-rams
Old 12-04-08, 01:01 PM   #6
Alias: brucek
User: #6
Yes, I mentioned it above in my post: You would also require a calibration file in REW.
It's also included in the REW Help Files.
A microphones response is never flat at its extremes, and so requires a file to render it flat. Without a calibration file, the measurement is usually quite inaccurate at the low end.
Old 12-04-08, 01:31 PM   #7
Alias: overmedium
Loc: nyc
User: #29524
Since: Nov 2008
brucek wrote: View Post
Yes, I see that you mentioned that, that's what prompted my inquiry of that information in the REW help file.
p.s. I couldn't find this information in the REW help file in regards to the 3 calibration files you mentioned. Sorry I'm being dumb (I'm just recovering the from flu.....)
Old 12-04-08, 02:25 PM   #8
Alias: brucek
User: #6
Three?
A microphone or SPL meter requires a single calibration file. The file is loaded into REW to render the microphone or SPL meter flat.
We have generic calibration files for a few types of SPL meters and also for a Behringer ECM8000 microphone available on our download page.
If you use an SPL meter of microphone that is different than the one we have files for, you will have to supply your own file through an independant calibration, or created from a set of specifications.
Old 12-04-08, 02:34 PM   #9
Alias: overmedium
Loc: nyc
User: #29524
Since: Nov 2008
Yes, you mentioned three in your earlier post: "Right now the only calibration files we have available is for the Galaxy CM140 SPL, Radio Shack SPL, and the ECM8000 mic."
This independant calibration you mentioned, is this something that I can do myself? Again sorry for my thick-headedness.....
Old 12-05-08, 07:26 AM   #10
Alias: brucek
User: #6
No, you send the mic to a certified calibrator such as West Caldwell and they create the file for you.
It's cheaper to simply purchase a good SPL meter such as the Galaxy CM-140 and use the generic file on our site.
Old 12-08-08, 08:24 PM   #11
Alias: overmedium
Loc: nyc
User: #29524
Since: Nov 2008
okay, thanks for clearing that up. I knew I shouldn't have been even thinking about REW when I was sick, but I was really bored and could muster just enough energy to type a reply but that proved to be not the wisest choice.
« Home Theater Shack > Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards »
binaural, making, mics, mistake?, rew?
