| SPL Meters | Mic's | Calibration | Sound Cards Behringer EURORACK UB802 or XENYX 802?Discuss Behringer EURORACK UB802 or XENYX 802? in the Equalization | Calibration forum; Behringer EURORACK UB802 or XENYX 802? I was on my way out the door to buy a mixer and noticed the thread "REW Cabling and Connection ... |
Views: 1766 - Replies: 8
| Behringer EURORACK UB802 or XENYX 802? I was on my way out the door to buy a mixer and noticed the thread "REW Cabling and Connection Basics" stated "REW connections using an ECM8000 microphone and XENYX802 preamp (recommended combo)" but the picture shows the Behringer EURORACK UB802. I assume there is a difference or Behringer would not make both. Which should I buy? The Euro Rack is 10 bucks cheaper which does not really matter to me I just want to get the mixer that is going to be correct and the easiest to setup. I have the ECM8000 on order. Could not find it retail in the Dallas, TX area. Thanks, Rastus | ||||
| | #2 | ||||
| Re: Behringer EURORACK UB802 or XENYX 802? The XENYX802 was basically a name change replacement for the EURO. Same device. I bought mine quite a while ago, so the picture is my own mixer. I don't know if they still sell the EURO, but matters not which one you get... brucek | ||||
| | #4 | ||||
| Re: Behringer EURORACK UB802 or XENYX 802? quick question.. I have a UB802 but I also have a audio interface with phantom power. Will I be ok by plugging the ecm8000 in the mic channel of the audio interface... or should i run the mic in the UB802 and run that into the "line in" of the audio interface... My guess either/or is fine... but I'm new to this side of the coin and etc... and i wanted to make sure if the mentioned arrangements make any difference... also what does it mean to bring something to "line-level" is that just getting a signal.. or "0" | ||||
| | #5 | |||||
| Re: Behringer EURORACK UB802 or XENYX 802? Quote:
Consumer Line level is a term to define a -10dBV (~315mvoltsRMS) typical nominal voltage level for a high impedance interface. brucek | |||||
| | #7 | ||||
| Re: Behringer EURORACK UB802 or XENYX 802? Looks like I may be able to get an older Eurorack MX602 for my ECM8000 for a lot cheaper than the newer models....it says it's able to do phantom power +48. I assume that's all I need to run REW correct? | ||||
| | #9 | |||||
Here's the link. http://www.behringer.com/EN/Products/MX602A.aspx Well I missed it on the ebays so I just got a Xenyx 802 off Amazon...got tired of messing with ebay. All total I would have only saved about 10 bucks had I won it...plus wouldn't have had a warranty to speak of. This is probably best me thinks. Also got a FBQ2496 instead of the 1194....just waiting for the shipments at this point. Last edited by Hunter844; 01-31-09 at 02:44 PM.. | |||||
