| SPL Meters | Mic's | Calibration | Sound Cards Mic MountDiscuss Mic Mount in the Equalization | Calibration forum; Mic Mount I have a mono-pod that has the correct size thread for the mic mount that comes with the ECM8000.
The ... |
Views: 276 - Replies: 1
| Mic Mount I have a mono-pod that has the correct size thread for the mic mount that comes with the ECM8000. The problem is my tripod is for my camera and it has a smaller thread. Is there some cheap simple adpter out there to mount the ECM8000 to a camera tripod? | ||||
| | #2 | ||||
| Re: Mic Mount Any camera store will have the adaptor you require so you will still be able to use your tripod. Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
