Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards
What else needs to be done?
Discuss What else needs to be done? in the Equalization | Calibration forum; What else needs to be done? I just inherited some new HT components. A Yamaha HTR-5280 Receiver and a JBL PB12 Subwoofer The receiver will be ...
Views: 262 - Replies: 3
Old 01-26-09, 11:09 PM   #1
New Member
Alias: Hambone
Loc: Gilbert, AZ
User: #32830
Since: Jan 2009
  Hambone_AZ is offline
The receiver will be used to process audio only, no video.
I have 3 inputs to the receiver, all using optical connections:
DirecTV HD DVR
Xbox 360
Popcorn Hour A-110
Which outputs to my 5 and now.1 speakers.
Speakers use 12 GA Speaker Wire.
Sub. Uses Line Level In
I want to get the most performance possible and therefore I want to make sure everything is just right.
So far I have:
I turned off all DSP programs and set for auto source selection.
Set size of all speakers to small.
I believe the receiver has a fixed crossover of 90 Hz. Is this right?
Set Subwoofer to LFE Mode. Bypassing subwoofer crossover, as receiver is handling this.
Set LFE OUT to Subwoofer.
Set Center Channel delay. 1ms
Used L/R Balance and master volume to achieve 75db SPL reading from both Front Mains. (At listening position) As measured on RS Digital SPL Meter. (Cool new toy)
Then adjusted center, surrounds, and sub to match 75db.
I set the Sub. to 0db on the receiver and used gain on the sub to adjust. Is this right?
What is the Phase selector used for? I have it set to 0, is this correct?
Is there anything that I am missing?
Will REW benefit me at all?
Thanks in advance for all the help.
Old 01-27-09, 08:02 AM   #2
Alias: brucek
User: #6
  brucek is online now
Re: What else needs to be done?
It will adjust the timing of the sub signal in relation to the mains. It is adjusted for the smoothest response over the crossover region.
It can be used to take a response of your sub and mains, allowing for better positionng of the speakers.
Old 01-29-09, 10:23 PM   #3
New Member
Alias: Hambone
Loc: Gilbert, AZ
User: #32830
Since: Jan 2009
Speaker location is more or less set. As this is a Living room and not a dedicated theater space.
So other than playing with the phase, is there anything else?
Old 01-30-09, 07:46 AM   #4
Alias: brucek
User: #6
If your speaker locations are fixed, then the only other option is to add an EQ to the sub if it doesn't have a smooth response (and they almost never do).
« Home Theater Shack > Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards »
done?
