Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards
Test-tone CD
Discuss Test-tone CD in the Equalization | Calibration forum; Test-tone CD Hello, I have to ask a really stupid question.. I'm not sure how to go about downloading the test tone ...
Views: 926 - Replies: 17
Old 02-03-09, 10:05 AM   #1
Alias: David
binkobonko's Avatar
Loc: near London
User: #33313
Since: Feb 2009
  binkobonko is offline
Test-tone CD
Hello,
I have to ask a really stupid question.. I'm not sure how to go about downloading the test tone CD. Am I right in thinking I save the files, then (after perhaps converting them) rip (or burn, even) them to a CD, so I can put them straight in my DVD/CD player, then play each frequency by track? I'm sure it's more complicated than that, but I have had a quick search and found nothing!
I know I could plug my PC straight into my AV receiver, but then I'm not sure how I would set the PC's volume to have minimal effect on setting my receiver to somewhere between 70db and 80db. Or does this actually matter, since with the volume I'm only aiming not to blow my sub anyway?
Does it matter if the test tone comes out my other speakers too? I'm guessing it should do, so do I just decouple them while I'm running the tones?
I ordered a test tone cd from Audio Concepts today, before finding this site. Feel free to tell me I don't really need it!
I have a Radio Shack 4050, the Excel graph, and a brain. I'm sure I can manage this. But please make any explanations extra simple..
Thanks
David
Old 02-03-09, 11:42 AM   #2
Alias: brucek
User: #6
  brucek is online now
Re: Test-tone CD
You don't really need it. Just download the test tones and burn a CD, and play it. You can also just plug the PC into the receivers AUX or CD input. The volume/wave out of the soundcard is set to some appropriate level (0.500) and then adjust the speaker volume with your receiver.
Generally you want to test the sub by itself, and graph that, and then you add the mains and do another measure and graph that. Fairly lengthy process. If you want to shut the mains off, simply disconnect them (with the power off).
To set the volume on the receiver, play a few tones between 50Hz-100Hz and get a feel if you have a huge peak or dip somewhere. Then choose a frequency that you feel is not in a dip or peak, and play it while adjusting the volume of the receiver to set ~75dBSPL on your Radio Shack meter at the listening position. Now don't touch the volume and do all your tones while writing them down or enter them into the excel file.
Old 02-04-09, 05:41 AM   #3
Alias: David
binkobonko's Avatar
Loc: near London
User: #33313
Since: Feb 2009
Re: Test-tone CD
Hi Bruce, thanks for replying. I've just got a few queries..
I only have a stock soundcard, so I'm plugging into the headphones socket, which is governed by a volume wheel, etc. Probably better to burn that CD, yeah?
I probably should have explained, I'm only doing a graph so I can set the parametric EQ on my SB12. I don't need to add the mains for that, right?
Apart from that, I think I understand. Thanks. Kind of wish I knew more about this stuff, but I spend too much time reading reviews!
One last thing, as you're obviously the person to ask? The BFD. With cash, and perseverance, I'm tempted to have a go. However, it would still cost me, I reckon, about $200. Long-term, though, I'd really like to get an Audyssey MultEQ Pro. Second-hand in the UK, they're down to about $1400. Hmm, I was going to ask you whether I should just put the money towards an Audyssey, but now I'm thinking, it really only depends whether I want to have a project in the meantime, so I've just answered my own question..
Old 02-04-09, 09:03 AM   #4
Alias: brucek
User: #6
Re: Test-tone CD
Any soundcard will have a line-out, which is easily volume controlled by the Windows Mixer.
If you're taking a response measurement using the manual method, then either CD or the PC method will work fine. With the PC, you can use windows media and play the full list of tones one after the other automatically in a playlist.
Well, you could get the EQ all set up and then when the mains are added you might (very likely) will have a problem at the crossover frequency caused by an interaction between sub and mains causing a dip or peak. This can be removed with the subs phase control. So, you want to do the sub alone and then the sub plus mains from ~15Hz-200Hz for both measures.
Most people who have Auto EQ also require a BFD to set the very low end. Auto EQ doesn't do a great job down to 15Hz....
If you want a worthwhile project, learn how to use REW. It will save you an enormous amount of time and it's far more accurate than the manual method.
Read and become familiar with the REW HELP files and the REW Cabling and Connections Basics.
Also note the REW information Index and the Download Page.
Old 02-09-09, 06:15 PM   #5
Alias: David
binkobonko's Avatar
Loc: near London
User: #33313
Since: Feb 2009
Re: Test-tone CD
Hi Bruce,
I got some test tones at 1Hz intervals downloaded free from Realtraps.com (great site), mapped out my sub and found a 7-8dB peak at 60hz. Unfortunately, when I set the PEQ on my SB12 to cut it, and did a rerun, it looked almost exactly the same! Heigh-ho. I've written to SVS about it, so let's see what they say.
I'm surprised to hear anyone with a MultiEQ might also need a BFD, given the cost and scope of the MultiEQ. To be honest, I'm not sure my sub goes down to 15Hz, or even 20Hz. I did find it interesting running tones and mapping a graph, so I will read up on REW.
Let's say I get the sub set up well, then map the sub and mains, how do I tell if I have a phase problem? The SVS owner's guide says to listen to a bass loop, like the intro on Godzilla, and have someone adjust the phase control gradually until you hear the most bass. But you're saying I can tell a bass problem from a comparing sub and sub/main graphs?
david
Old 02-09-09, 07:07 PM   #6
Alias: brucek
User: #6
Re: Test-tone CD
To see if it works, set a exaggerated filter on the PEQ (i.e. 50Hz - 20dB) and play a tone at 50Hz and turn the filter on and off.
Do a measure of the sub and mains and observe the crossover area and adjust the phase for the smoothest transition.
Of course, if you run the RTA in REW, you simple adjust the phase while watching the screen dynamically change. Makes it kinda easy.
Old 02-09-09, 08:00 PM   #7
Alias: David
binkobonko's Avatar
Loc: near London
User: #33313
Since: Feb 2009
Re: Test-tone CD
thanks Bruce
Old 02-11-09, 01:55 PM   #8
Alias: David
binkobonko's Avatar
Loc: near London
User: #33313
Since: Feb 2009
Re: Test-tone CD
Right, I did set an exaggerated cut, and got a massive drop. I've had a fiddle with it, and brought my 60Hz peak down as much as I think is possible. There should be "before" and "after" graphs attached.
I also had a long chat with a guy at my local audio shop. He suggested moving my sub around, and rotating it, before I started fiddling with EQ, to get the best, i.e., loudest sound. He also suggested setting my speakers to large, which contradicts what I've read previously. They're not sats, I've got two old Wharfedale 505.2s for fronts, a Paradigm CC-350 centre and two Axiom QS4 surrounds. I've set my Arcam AVR300 bass management to "large + sub", so all bass frequencies go everywhere. He also suggested trying a lower crossover, between 40Hz and 50Hz, as my speakers aren't tiny sats, but "full range". I have done this, and it does seem to make a difference for the better.
Speaker set up is a nightmare! I'm only really starting to fret now about calibrating my sub because when I picked up my Arcam last weekend, from a guy who was upgrading to the AVR350, he gave me a quick demo. He had B&W M1's and a PV1. The bass from the PV1 was like nothing I've heard from my SB12, a different league of presence, dynamism and tactile feel. Okay, it did cost £950 to my SB12's £500, but still. I asked him whether he'd calibrated it (I thought this might explain its performance). He hadn't. I want my sub to sound a bit more like that - it's not exactly a duffer, right?
I think it's time to venture into REW. I've been reading through the various files, and I think I can work it out. To start with, I'll just try to get a curve, and worry about a BFD later. I've bought the leads I'll need, I just need a soundcard.
I could get a Creative Live 24-bit USB External, or an Audigy 2ZS for my laptop, which I'd prefer. Bearing in mind I want to keep things as simple as possible, and maximise my chances of being able to follow the REW instructions, would a Creative Live be the best choice, or doesn't it matter that much?
Feel free not to address most of the above - I'm only really asking about the soundcard. I'm finding it quite interesting, so far, though.
david
Old 02-11-09, 02:01 PM   #9
Alias: brucek
User: #6
Re: Test-tone CD
The Creative Live is used by quite a few members here. It's inexpensive and works. It didn't work with Vista until recently and I don't believe it works with Vista 64 bit yet.
Old 02-11-09, 02:33 PM   #10
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
Re: Test-tone CD
binkobonko wrote: View Post
I use the Creative soundcard live 24 and it works fine (I'm using XP).
Even if you asked not to address your comment, I will .
Personally I think is better to use the center and surround speakers as small, but is okay to set the front to large depending on their frequency response, in your case they're okay (that's what I did in my setup, I compared the response between small and large and it was a big difference).
You can play with the crossover, again, using REW showed me that the best crossover was 80Hz.
About the bass management, my Yamaha RXV2700 has three options: Front, Sub and Both. I used REW and compared the response with each option, the best response was setting the sub output to "Sub", so my set up is front speakers "large", all other speakers "small", crossover 80Hz and sub output to "Sub" ...hope this helps
Old 02-11-09, 02:55 PM   #11
Alias: David
binkobonko's Avatar
Loc: near London
User: #33313
Since: Feb 2009
Re: Test-tone CD
I don't have Vista (thank god), and I would have just gone with the Creative Live, except I saw an Audigy 2 ZS go on avforums.com a month ago for $25 delivered. That's so cheap, it's bald, in a nest, and squawking for worms. I can buy a Creative Live new in the UK for about $58.
Well, it's interesting to know that I'll be able to use REW to physically see what works best. I will try setting my fronts to large, and keeping the rest small.
Anyone have any feelings on the PV1 vs the SB12-Plus?
Old 02-11-09, 04:20 PM   #12
Alias: David
binkobonko's Avatar
Loc: near London
User: #33313
Since: Feb 2009
Re: Test-tone CD
this explains a few things about my SB12-Plus:
The “Level” control is exceedingly non-linear, getting virtually all its action in the last fifty-percent of knob travel – i.e., between straight up and “Max.”
and
the “Q” knob appears to be plagued by the same non-linearity as the “Level” knob, getting all its action in only fifty-percent of its travel.
and would account for the lack of cut I previously experienced, and why it's working now. it might mean I can get a wider effect by increasing Q too!
small steps..
thanks to Wayne for mentioning this in his review
Old 02-11-09, 06:02 PM   #13
Alias: brucek
User: #6
Re: Test-tone CD
and
Well, the controls should work that way.
That's because they're audio taper potentiometers and not linear potentiometers.
If audio equipment used linear pots, the level would go from nothing to near full in about a tenth of a turn. If you then turned it from there to fully clockwise, you wouldn't notice much difference.
This is because we hear logarithmically. An audio taper pot at halfway between fully off and fully on, only accounts for about 10% of its resistance.
So, it's supposed to be non-linear. It allows finer control.
Old 02-12-09, 04:40 AM   #14
Alias: David
binkobonko's Avatar
Loc: near London
User: #33313
Since: Feb 2009
Re: Test-tone CD
i think then that I may have received an outdated user guide with my sub - it shows pictures of vertically stacked dials, with incremental hash marks, and says each mark for Q is 0.1 octave, each for Level is 1.5dB, and each for Freq 5Hz. Perhaps these dials are from another sub, because SB12 dials run horizontally. Also, my dials have no hash marks. At first this was frustrating, now I understand why!
But the REW will mean that, "Where we're going, we don't need hash marks!", right?
Old 02-17-09, 03:10 PM   #15
Alias: David
binkobonko's Avatar
Loc: near London
User: #33313
Since: Feb 2009
Re: Test-tone CD
hi bruce,
great news: i got a soundcard for REW!
not so great news: i bought an audigy 2 zs (it was cheap, and i'm using a laptop)
I've seen that two year old thread from pmandt, so I suppose i'm going to have all sorts of fun getting it set up.
Sure I'll have some queries at some point, but of course I'll check threads before posting.
I'm really excited! Thanks again for your help and encouragement to date.
Old 02-17-09, 07:25 PM   #16
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is offline
Re: Test-tone CD
Here's how the Audigy 2 ZS mixer and advanced controls need to be set up, to access the advanced controls click the red + in the REC panel:
Old 02-18-09, 04:46 AM   #17
Alias: David
binkobonko's Avatar
Loc: near London
User: #33313
Since: Feb 2009
Re: Test-tone CD
Thanks very much John
Any idea where I might download a copy of the mixer that won't give me a "initialising mixer engine" error??
Old 02-18-09, 08:10 AM   #18
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is offline
Re: Test-tone CD
The only place I know to get the Creative software is from the support section of their website. Check the manual also as it is sometimes important to plug the card in at the correct point in the installation process.
« Home Theater Shack > Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards »
test-tone
