Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards
Soundcard .cal file versus SPL meter .cal file?
Discuss Soundcard .cal file versus SPL meter .cal file? in the Equalization | Calibration forum; Soundcard .cal file versus SPL meter .cal file? Hi all - Quick question that I can't seem to answer from reading the help files. I am using the ...
Views: 426 - Replies: 2
Old 02-06-09, 09:26 AM   #1
New Member
Alias: Jason
Loc: Austin, TX
User: #19832
Since: Apr 2008
  myrison is offline
Question Soundcard .cal file versus SPL meter .cal file?
Hi all -
Quick question that I can't seem to answer from reading the help files. I am using the newer RS Analog meter for calibrating my sub and cannot figure out if I should be using a self-generated CAL file from my soundcard (created through a loopback connection from SPL meter to soundcard) as described in the help files or if I should use the SPL-meter-specific .cal files that are available for download on the forums.
Can someone please advise?
Thanks,
Jason
Old 02-06-09, 10:45 AM   #2
Alias: brucek
User: #6
  brucek is online now
Re: Soundcard .cal file versus SPL meter .cal file?
They're both used, and are both necessary.
The soundcard cal file is created using the soundcard calibration routine and saved and pointed to by REW on the Settings page under Soundcard tab.
The meter calibration file is downloaded and saved and pointed to by REW on the Settings page under the mic/meter tab.
Old 02-06-09, 12:25 PM   #3
New Member
Alias: Jason
Loc: Austin, TX
User: #19832
Since: Apr 2008
  myrison is offline
Thank you for the response Bruce. That's what I needed.
« Home Theater Shack > Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards »
.cal, file, file?, meter, soundcard, versus
