| SPL Meters | Mic's | Calibration | Sound Cards Testing component frequency response?Discuss Testing component frequency response? in the Equalization | Calibration forum; Testing component frequency response? How do you test the frequency response of amps, preamps, cd players, sound cards, ect? What equipment/software is needed/recommended? Thanks.... |
Views: 328 - Replies: 5
| | #3 | |||||
| Re: Testing component frequency response? Quote:
Testing an amplifier is impractical and costly, since this is a device that requires high power loads to perform the test. brucek | |||||
| | #4 | ||||
| Re: Testing component frequency response? You can do an amplifier fr in a very rigged up way, but at very low power levels only. Any good amp should maintain it's FR at higher power levels though. It is semi dangerous and you can fry equipment easily. I've fried a soundcard and shorted out and sparked off of my mixer board when something accidently got unplugged. I run REW out into the amp and then rig up a cable to run from the amplifier outputs back into a mixer board. I would not try it with anything else. Mixers are made to handle moderate high voltage levels, so you can then use it to control the voltage back out into your SC and laptop. You also have to calibrate for your mixer and SC. Overall it's risky and really easy to damage something so I don't recommend trying this. | ||||
| | #5 | |||||
![]() brucek | |||||
| | #6 | ||||
| Re: Testing component frequency response? Understandable... Short of getting a professional rig or test done it's what you've got though. I did stress the "proceed at your own risk" portion. ![]() | ||||
