Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards
SoundCard:Yamaha Audiogram3
Discuss SoundCard:Yamaha Audiogram3 in the Equalization | Calibration forum; SoundCard:Yamaha Audiogram3 What do you think about this one? http://www.yamahasynth.com/products/...ram/index.html http://www.sweetwater.com/store/detail/Audiogram3 I visited Yamaha Showroom and salesman told me recommend this one ...
Views: 936 - Replies: 18
Old 02-27-09, 03:55 PM   #1
Alias: Bank
User: #34522
Since: Feb 2009
  zephyrwinter is offline
I visited Yamaha Showroom and salesman told me recommend this one to me.
He said it's 12mS delay. Is it over speaking?
Old 02-27-09, 06:07 PM   #2
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
Re: SoundCard:Yamaha Audiogram3
I'd like it better if it was any color but white...
Are you asking if it will work for REW? Any soundcard with a USB connection and a line input and line output will work.
Old 02-27-09, 08:53 PM   #3
Alias: Bank
User: #34522
Since: Feb 2009
Thanks.
Anyone has table of latency delay time of each soundcard?
It would be benefit for all those who wanna buy soundcard.
thanks again
Old 04-30-09, 09:49 PM   #4
Alias: Jared
User: #2200
Since: Aug 2006
  JRace is offline
Just got one today with a Behringer ECM8000.
Will be a few days before I can give my impressions...emergency trip to the vet today
Old 06-06-09, 07:07 PM   #5
Alias: Jared
User: #2200
Since: Aug 2006
  JRace is offline
Finnally getting around to taking some measurments.
I have:
ECM8000 mic
connected to Audiogram 3:
Stereo out going to receiver (Denon 4308ci)
This unit (Audio3) is a USB interface as well as phantom power for the Mic.
Can I use it as the soundcard, or do I need to use my Soundblaster External?
Old 06-06-09, 09:09 PM   #6
Alias: brucek
User: #6
  brucek is online now
Sure, looks fine.
Old 06-06-09, 11:52 PM   #7
Alias: Jared
User: #2200
Since: Aug 2006
  JRace is offline
For the soundcard calibration how would I connect the loopback?
Would it be: XLR - RCA cable connecting the MIC to the OUT?
Initial connection produced feedback when the input level or the output level was increased.
Connected as so:
ECM8000 -> MIC input
RCA Ouput -> AVR input
Audiogram 3 -> Laptop (USB)
Any ideas?
Old 06-07-09, 07:40 AM   #8
Alias: brucek
User: #6
No, connect the line-out to line-in to create the file. You can use the line-out to mic-in, but you need to fabricate a pad to alter the levels, and it's not really necessary. Experience shows that the small mic preamp does not affect the response enough to bother. Most of the response rolloff is in the line amps.
Old 06-07-09, 12:02 PM   #9
Alias: Jared
User: #2200
Since: Aug 2006
  JRace is offline
Here is my first attemp at calibration:
On The audiogram 3 there is both Input and output level controls.
It was very tough to set these without the meter clipping. The closest I could get was -3.5.
Old 06-07-09, 12:21 PM   #10
Alias: brucek
User: #6
Looks like some sort of treble control or EQ is turned on in the units application software.
Have you shut off all the effects etc in the application?
Old 06-07-09, 12:32 PM   #11
Alias: Jared
User: #2200
Since: Aug 2006
  JRace is offline
The only software included was recording software that I have not installed.
The unit interfaces with my laptop through the standard win USB soundcard drivers.
Old 06-07-09, 01:32 PM   #12
Alias: brucek
User: #6
Are you using a single RCA connector on the right channel only for the loopback?
Old 06-07-09, 03:56 PM   #13
Alias: Jared
User: #2200
Since: Aug 2006
  JRace is offline
I had both the LT and RT connected.
Here is the calibration this time, RT only:
The first graph had a mic/meter Cal graph loaded...which explains the odd shape.
This new graph is the soundcard only.
Old 06-07-09, 04:10 PM   #14
Alias: Jared
User: #2200
Since: Aug 2006
  JRace is offline
and here is my calib graph for a creative soundblaster external USB:
This looks like what I expected.
As for the Yamaha, could that be the actual response?
Old 06-08-09, 06:51 AM   #15
Alias: brucek
User: #6
I can't imagine a response that bad. It makes no sense. There has to be something causing it - or perhaps there's a fault in the unit.
Old 06-08-09, 02:54 PM   #16
Alias: Jared
User: #2200
Since: Aug 2006
  JRace is offline
With just the audiogram 3 I could not increase the levels without fedback.
With the audiogram 3 sending the line out to the soundblaster USB there was no feedback.
There is no control software for the Audiogram 3 and you must use the windows USB control.
With the soundblaster you can turn off monitoring "what U hear".
Perhaps that is the issue?
Old 06-08-09, 06:49 PM   #17
Alias: brucek
User: #6
Check the Windows Playback Mixer to see if line-in is muted or not (it should be muted). That is the indication of monitoring being turned on.
Old 09-21-09, 09:18 PM   #18
New Member
Alias: Clinterinette
User: #42317
Since: Sep 2009
  Clinterinette is offline
Hi everyone. I think I'll buy this item, but personally my guitar style is more like "death metal" and I wanted to know if Audiogram 3 combined with Cubase can "create heavy guitar distorsion"? I'm sorry I don't know nothing about the "PC recording"! Thank you!
Old 09-22-09, 08:52 AM   #19
Alias: Wayne
Loc: Katy, Texas
User: #8
I think you'll have better luck posting your question at the Tape Op Message Board. It's a forum for recording hobbyists and pros.
« Home Theater Shack > Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards »
audiogram3, soundcard:yamaha
