Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards
ok first thing first
Discuss ok first thing first in the Equalization | Calibration forum; ok first thing first i have just download the files and install it.. reading the help menu and got to SPL calibrating pages.. what ...
Views: 348 - Replies: 13
Old 03-06-09, 01:08 AM   #1
Alias: aquira
User: #34864
Since: Mar 2009
  priatnasuardi is offline
what i read is.. the sistem require us to use additional spl meter to calibrate it with REW..
am i correct??
my Q is
can i perform this test without using SPL meter?? will it be accurate..??well a +-2db is ok for me
im going to use it to test my studio room..
im using a presonus firestudio project and use behringer ecm8000
thanks in advance..
Old 03-06-09, 07:57 AM   #2
Alias: brucek
User: #6
  brucek is offline
Re: ok first thing first
Yes, you can use it without an SPL meter (although they are extremely inexpensive).
Just estimate the 75dBSPL and Calibrate REW to that 75dBSPL.
It is very difficult to set speaker levels without an SPL meter - I thought everyone had one?
Old 03-06-09, 08:46 PM   #3
Alias: aquira
User: #34864
Since: Mar 2009
brucek wrote: View Post
havent check shops around yet..but im in a very thight budget and think i cannot afford to spend money on what im going to use just one time...hmm..
is there any other way i can get around this..??
Old 03-06-09, 10:15 PM   #4
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
not easily, if you dont know what 75db sounds like it is near impossible without an SPL meter of some sort.
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 03-07-09, 12:28 AM   #5
Alias: Jim
Loc: Wetumpka
User: #630
  JimP is offline
priatnasuardi wrote: View Post
You really don't have a choice in this. You have to reset the system each time you restart it and to do so you need an spl meter.
Old 03-07-09, 07:12 AM   #6
Alias: brucek
User: #6
  brucek is offline
Yes, I already answered your question above...
Old 03-07-09, 09:19 AM   #7
Alias: aquira
User: #34864
Since: Mar 2009
how to estimate..??
what sort of guide that i can use?
ok lets say i didnt calibrate it and just use what ever number that will come up when i plug in the mic..how accurate will that be??
Old 03-07-09, 09:46 AM   #8
Alias: brucek
User: #6
  brucek is offline
how to estimate..??
A reasonable level. Not ridiculously loud, not ridiculously quiet. It ain't that important.
As I said, set a reasonable level, run the Calibrate button and set to 75dB - that's it. If it happens to be 82dB, then it makes no difference. The graph will be accurate in the relative rather than accurate in the absolute.
Old 03-07-09, 11:39 AM   #9
Alias: Kal
Loc: NYC + CT
User: #1881
Since: Aug 2006
  Kal Rubinson is offline
I bought 2 SLMs at flea markets recently. They were cheap and work fine. Keep looking.
Kal
Old 03-07-09, 12:07 PM   #10
Alias: brucek
User: #6
  brucek is offline
Keep looking.
Well exactly. Or here's one for $2.26 on e-bay.
Old 03-07-09, 09:17 PM   #11
Alias: aquira
User: #34864
Since: Mar 2009
i see,...
it goes up to 7 now, and the cost to ship it to bali will be 7-8 times and the price will be 10 times as soon as it arrive here..
i think i have the solution for this..
ill go to one of those car stereo installer..ask one of their tech to go to my house...
Old 03-08-09, 08:10 AM   #12
Alias: aquira
User: #34864
Since: Mar 2009
ok ...let say i have calibrate it..
i want to know my room modes...
how shall i know if the room has a problem in certain freq...
after i saw the graph..i saw it like a kid trying to draw a straight line
Old 03-08-09, 08:22 AM   #13
Alias: brucek
User: #6
  brucek is offline
Read and become familiar with the REW HELP files and the REW Cabling and Connections Basics.
Also note the REW information Index and the Download Page.
Old 03-08-09, 08:39 AM   #14
Alias: aquira
User: #34864
Since: Mar 2009
great brucek...
thanks..
« Home Theater Shack > Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards »
thing
