Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards
Alesis MultiMix soundcard calibration issues
Discuss Alesis MultiMix soundcard calibration issues in the Equalization | Calibration forum; Alesis MultiMix soundcard calibration issues Some months back I won an auction for a Behringer 802 on eBay, but the seller screwed up and sent ...
Views: 432 - Replies: 0
Old 03-11-09, 05:38 PM   #1
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
Some months back I won an auction for a Behringer 802 on eBay, but the seller screwed up and sent me an Alesis MultiMix 8 USB instead. Without going into the details, I got to keep the Alesis, even though it’s considerably more expensive than the Behringer. It didn’t take me long to figure out that since the MultiMix has a USB output, it has the capability of being a “one package” option for REW, compared to the 802, which must be used with a separate USB sound card.
Problem is, I’m having trouble generating a viable soundcard calibration file with this thing (this is only the second time I've calibrated a soundcard, the first being the Soundblaster I've been using). Separate measuring attempts using different combinations of Input and Output Device options (i.e., "Default Device," "USB Audio") have resulted in graphs like these:
Changing various OS options offered for the Alesis has made no difference. As best as I can tell, the problem is that the Alesis doesn’t provide the option of letting REW control the input level:
Name:  Alesis calibration 3.JPG
When I instead attempt to use the Alesis’ various trim and gain controls to adjust the level during the calibration routine, nothing happens at first, and then suddenly the signal goes from nothing to clipping, both with the REW input meter and the Alesis’s output meter. At that point the level is very “touchy” and difficult to adjust. When I am able to stabilize the signal level and run the soundcard calibration routine...
Name:  Alesis calibration 4.JPG
...I get graphs like the ones posted above.
If I disconnect the Alesis from the computer, its own meter level remains stable, which tells me the meter is not showing a signal originating from REW. It appears that the Alesis is having an internal feedback problem.
It’s looking like my only option for getting a calibration file will be to feed the MultiMix analog inputs and outputs though my Soundblaster soundcard. Any thoughts?
« Home Theater Shack > Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards »
alesis, calibration, issues, multimix, soundcard
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332
