| SPL Meters | Mic's | Calibration | Sound Cards Why only these SPL meters?Discuss Why only these SPL meters? in the Equalization | Calibration forum; Why only these SPL meters? Is it right that you can only use the Radioshack or Galaxy SPL meters with REW?
if this is the ... |
Views: 501 - Replies: 6
| Why only these SPL meters? Is it right that you can only use the Radioshack or Galaxy SPL meters with REW? if this is the case can someone please explain to me why,is it a connection thing or something? Thanks. | ||||
| | #2 | ||||
| Re: Why only these SPL meters? Hi Mark, Welcome to the Shack, The reason is because a calibration file needs to be made for each and every mic used with REW and as both the Galaxy140 and the Radio Shack are by far the most common SPL meters with a line out these were the only files made other than the ECM8000 (you still need an SPL meter if you use the ECM). Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #4 | ||||
| Re: Why only these SPL meters? You can use any SPL meter with a line output, but the accuracy will be unknown. Not an issue if your aim is to find a good position for your sub, for example, as the response changes between different positions are much larger than any meter inaccuracies at subwoofer frequencies. | ||||
| | #5 | ||||
| Re: Why only these SPL meters? [QUOTE=JohnM;159337]You can use any SPL meter with a line output, Thanks John, Unfortunately mine doesnt have a line output so i will still have to go to ebay, i know the difference between analogue and digital but which is the preferred and what would i gain from digital except for a more accurate measurement? I do apologise if it sounds daft! Mark. | ||||
| | #6 | |||||
| Re: Why only these SPL meters? Quote:
If it's analog, be sure to look for the newer model. (see the downloads page to get model numbers) brucek | |||||
