| SPL Meters | Mic's | Calibration | Sound Cards USB Sound cards with Phantom Power for REWDiscuss USB Sound cards with Phantom Power for REW in the Equalization | Calibration forum; USB Sound cards with Phantom Power for REW I've a HP mini-note book and I need an external USB sound card that meets the following criteria's
-works with ... |
Views: 1132 - Replies: 19
| I've a HP mini-note book and I need an external USB sound card that meets the following criteria's -works with ECM8000. That requires it to have phantom power -is Vista 32-bit/64-bit compatible. People here seems to use M-Audio pre but some people does not seem to like it. E-MU Tracker Pre USB 2.0 is priced lower than M-Audio and has the features that I need. I searched the forum and could not find anybody using it. Is there a problem with this sound card. One stupid question. I plan to buy SVS AS-EQ1 and was wondering if that will be compatible with REW? If its compatible then I don't need to buy USB sound card My setup consist of Integra DTC-9.8 Outlaw Amp SVS PB2+ sub Salk Song Speakers | ||||
| | #2 | ||||
| Re: USB Sound cards with Phantom Power for REW I am fairly sure that you wont find a sound card for a PC that has the ability to supply Phantom power. You will need to buy a Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #3 | ||||
| Re: USB Sound cards with Phantom Power for REW Hey Tony, I cannot post the link (due to low post count) but the E-MU specs says that it has the Phantom Power. Would this not work with REW and ECM8000 mic. E-MU Tracker Pre USB 2.0 Features: 24-bit/192kHz A/D and D/A converters (A/D and D/A: 112dB measured SNR performance) deliver USB audio fidelity, gold-plated connectors for better audio quality Preamplified analog signals are available before the A/D converters, allowing the Tracker Pre to be used as a standalone stereo microphone preamp (using optional power supply) Hardware zero-latency direct monitoring (mono or stereo) with continuously variable level control Plug-and-play operation with hands-on control of all major functions like direct monitoring level, headphone level, preamplifier gain, and more Independent ground lift switches for optimal audio fidelity/flexibility USB bus powered (can also be powered using optional 5V power supply) Two Class-A ultra-low noise Mic/Line/Hi-Z preamplifiers Cross-platform support (Mac OS X and Windows XP32/XP64/Vista32/Vista64) and compatibility with most popular audio/sequencer applications (ASIO2, WDM, MME, Apple Core Audio and Core MIDI supported) Signal Level & Clip indicators Left/Right Gain controls Direct Monitor level control Direct Monitor On/Off & Mono-Stereo Switch Headphone jack Headphone Level control 5 VDC Power Adapter (optional) Phantom Power on/off switch 2 balanced outputs 2 unbalanced TRS insert jacks Hi-Z/Line/Mic inputs 1/8" Stereo Mic input | ||||
| | #4 | ||||
| Re: USB Sound cards with Phantom Power for REW Given what you posted it does seem that it can supply phantom power. If that is the case then I do believe that it should work. Is this the one? http://www.emu.com/products/zoom/17511.html Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #5 | ||||
| Re: USB Sound cards with Phantom Power for REW Yes I think it should work but I've been unable to find anybody who is using it. Since I'm new to all this I want to buy a tried and tested product. Is there a comprehensive list of USB sound cards that are compatible with REW? Upon reading i found a few -M-Audio Fast Track -Sound Blaster -Tasman | ||||
| | #6 | ||||
| Re: USB Sound cards with Phantom Power for REW My goal is to minimize the number of components required to use REW. Here is the list that I think I need to take REW measurements - USB Soundcard with Phantom Power - Behringer ECM8000 Mic - XLR Mic Cable - Mic Stand - RS SPL meter Is there anything i'm missing from the list? Last edited by malikarshad; 04-22-09 at 02:46 PM.. | ||||
| | #8 | |||||
| Re: USB Sound cards with Phantom Power for REW Quote:
| | #9 | |||||
the AS-EQ1 is measuring. My current setup is the EMU 0404 USB supplying phantom power to an Earthworks M30. The 0404 is pretty bulky but has decent MIC inputs and has audio outputs. I was also looking at the Centrance Micport Pro, it is not a soundcard but a USB MIC interface. It is very compact and does 48V phantom power. It costs about $30 more than the M-Audio. Last edited by Tong Chia; 05-31-09 at 07:19 PM.. | |||||
| | #10 | ||||
| Re: USB Sound cards with Phantom Power for REW Thanks guys for your responses. I'm all set right now with REW. I bought a emu 0404 usb with ECM8000 mic and have been pleased with the result. I also have the AS-EQ1 since the past week and have used it numerous time to compare the graphs. REW has been of tremendous help in acheiving what I want. It has also been a great troubleshooting tool for the issue i was having with AS-EQ1 level matching (although it was my mistake). | ||||
| | #11 | |||||
- Chris | |||||
| | #12 | |||||
I commented on this when someone else wanted to use that type of solution in this post. brucek | |||||
| | #13 | ||||
| Re: USB Sound cards with Phantom Power for REW People wondering just How Good the EMU USB cards are should read Bill Waslo's review of the 0202 used with Praxis, the well-regarded $1K measurement program he developed. To say the least, he was impressed with the noise and distortion performance. "I even saw it down to 0.0003% THD at midband, which is insanely low" "This is the first card in which I've seen a substantial improvement when going from 16bits to 24bits" "So, I'd say its a great 24/96kHz card and a not-as-great one at 192kHz. Of course considering how few USB cards even do 96kHz decently, that's quite an accomplishment." http://www.libinst.com/EMU%200202%20USB.htm | ||||
| | #14 | |||||
![]() brucek | |||||
| | #16 | |||||
http://www.emu.com/products/product....&product=17511 | |||||
| | #17 | ||||
| Re: USB Sound cards with Phantom Power for REW Hi all, Not to throw a wrench in the gears here, but Tascam also has a very good option with all the requirements in one simple package. It's the Tascam US-144: http://www.sweetwater.com/store/detail/US144/ I've had very good results with this unit. EMU products are awesome as well. Just wanted to post an option for those that do not have one yet. Ray Ray Happy Listening!!! Listen with an open mind and heart!!! | ||||
| | #19 | |||||
Ray Ray Happy Listening!!! Listen with an open mind and heart!!! | |||||
| | #20 | |||||
| Re: USB Sound cards with Phantom Power for REW Sorry for reviving an old thread, but... Quote:
Regardless, has anyone compared the EMU Tracker and the Tascam? Any problems with drivers under OSX? I'm trying to stay away from M-Audio, as they can't seem to write a driver worth... well, you know ![]() | |||||
