Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards
REW with M-audio 610
Discuss REW with M-audio 610 in the Equalization | Calibration forum; REW with M-audio 610 I have this profire 610 and radioshack meter would it be best to get the ecm 8000 mic also can ...
Views: 254 - Replies: 1
Old 07-07-09, 02:55 AM   #1
Alias: jwhite
Loc: Houston,Texas
User: #6296
  jwhite8086 is offline
I have this profire 610 and radioshack meter would it be best to get the ecm 8000 mic also can I use the digital coax output to reciever and firewire to pc or must I use all 1/4" cables ?
Old 07-07-09, 07:34 AM   #2
Alias: brucek
User: #6
  brucek is online now
Re: REW with M-audio 610
For full range measurements, you'll require the ECM8000, but for simple home use for subwoofers, the Radio Shack meter would be fine.
You can certainly use the firewire to the PC (as long as it isn't a MAC), but you must use analog for the mic and connection to the receiver. There would be no way to calibrate it otherwise.
« Home Theater Shack > Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards »
m-audio
