Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards
Galaxy CM-140 questions
Discuss Galaxy CM-140 questions in the Equalization | Calibration forum; Galaxy CM-140 questions I'm considering the Galaxy mic as an upgrade from using an ECM8000 and mixer. From what I've read, it sounds ...
Views: 319 - Replies: 3
Old 08-05-09, 11:43 AM   #1
Alias: Jim
Loc: Wetumpka
User: #630
  JimP is offline
From what I've read, it sounds like I can connect the CM-140 directly into my sound card using a 3.5 mono plug. I will not need a mixer/phantom power supply/preamp with the CM-140....is that correct?
Since it furnishes its own power, does the 9 volt battery last a while (a few months) or is it a problem due to constant replacing? I understand this depends heavily on how much its used. As a hobbies who goes in burst with this calibration thing, I don't want to be replacing batteries each time I pull it out.
Does the CM-140 have a slot for a tripod screw for mounting?
Are the available calibration files from this site close enough or do these mics vary enough where they require to be sent off for an individual calibration.
Thanks in advance
Old 08-05-09, 11:57 AM   #2
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Re: Galaxy CM-140 questions
JimP wrote: View Post
I would not consider it an upgrade however it is a good meter and does eliminate all the connection issues.
Yes that is right.
Ive had my same rechargeable 9v battery in the 140 for over 6 months and it still works fine.
Yes
as long as your not rough on the 140 you should have no need to do any calibrations to it at all.
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 08-23-09, 07:01 PM   #3
Gold Supporter
Alias: Kevin
Loc: Nazareth, PA
User: #17281
Since: Feb 2008
  zero the hero is offline
is it really only good to 31.5hz?
Old 08-23-09, 07:11 PM   #4
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
No, once you use the calibration file with REW is goes much lower. Even without it is still usable to about 20Hz
Home theater:
Two Channel system:
My Webpage
« Home Theater Shack > Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards »
cm-140, galaxy, questions
