| SPL Meters | Mic's | Calibration | Sound Cards Mic orientationDiscuss Mic orientation in the Equalization | Calibration forum; Mic orientation Hello Shackers,
i read a lot in this forum and learned really so much. Now its time to get active
Views: 240 - Replies: 3
| Mic orientation Hello Shackers, i read a lot in this forum and learned really so much. Now its time to get active ![]() ![]() I just tried the actual cal file (below) from the ECm8000 from the download section. My question is: is this file calibrated from horizontal or vertical avareging? I would like to buy a callibrated mic, but at the moment it really is a little bit confusing to me. For frequency response at the listening position i would like to orient the mic vertical with a 10° angle. Is it now better to use a cal file for vertical calibration or horizontal. Or to is it better not to angle the mic to get a more exact high frequency response. thank you so much ![]() 5.0 -19.49 5.6 -17.79 6.3 -16.08 7.1 -13.99 8.0 -12.39 9.0 -10.41 10.0 -8.60 11.2 -6.98 12.5 -5.48 14.0 -4.17 16.0 -3.05 18.0 -2.13 20.0 -1.40 22.4 -0.88 25.0 -0.54 28.0 -0.32 31.5 -0.20 35.5 -0.09 40.0 -0.01 45.0 0.07 50.0 0.11 56.0 0.16 63.0 0.16 71.0 0.14 80.0 0.11 90.0 0.07 100.0 0.05 112.0 0.05 125.0 0.04 140.0 0.04 160.0 0.02 180.0 0.04 200.0 0.06 224.0 0.08 250.0 0.09 280.0 0.10 315.0 0.11 355.0 0.10 400.0 0.17 450.0 0.20 500.0 0.09 560.0 0.19 630.0 0.14 710.0 0.16 800.0 0.12 900.0 0.03 1000.0 0.00 1120.0 0.10 1250.0 0.12 1400.0 0.02 1600.0 -0.28 1800.0 0.11 2000.0 0.19 2240.0 -0.15 2500.0 0.21 2800.0 0.14 3150.0 0.08 3550.0 0.44 4000.0 0.67 4500.0 0.78 5000.0 0.89 5600.0 1.28 6300.0 1.78 7100.0 1.85 8000.0 2.55 9000.0 3.93 10000.0 4.46 11200.0 4.29 12500.0 4.73 14000.0 4.99 16000.0 5.35 18000.0 5.70 20000.0 5.37 22400.0 5.09 25000.0 4.48 | ||||
| | #2 | |||||
| Re: Mic orientation Quote:
For listening position measurements we recommend that the meter or mic be oriented vertically with a forward angle of about 10 - 20 degrees to capture a good mix of direct and reflected sound for "room" measurements. For near field measurements we recommend a horizontal position. brucek | |||||
| | #4 | |||||
But, if you have a vertical cal file, use it that way. The vertical and horizontal files are close enough, that we weren't about to provide them both as a generic set since the errors in using a generic file overwhelm any small differences in those two files. If anyone is really concerned about accuracy in a home setting (where a mic movement of a few inches can realize several dB change) then they should get their mic calibrated. brucek | |||||
| Bookmarks |
| Tags |
| orientation |
| Thread Tools | |
