Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards
OSX and MOTU sound card
Discuss OSX and MOTU sound card in the Equalization | Calibration forum; OSX and MOTU sound card Hi guys, I recently installed REW and do not see my sound card listed as an option. (MOTU 828 Mk2 ...
Views: 175 - Replies: 2
Old 09-02-09, 08:30 PM   #1
Alias: JC
User: #41476
Since: Sep 2009
  StudioPadank is offline
Hi guys,
(MOTU 828 Mk2 OSX 10.4.10)
I made sure that it is the default in the Audio/MIDI setup and restarted
REW. I feel like I must be missing something simple.
Any ideas?
Thank you!
JC
Old 09-03-09, 08:50 AM   #2
Alias: brucek
User: #6
  brucek is offline
Re: OSX and MOTU sound card
Any ideas?
You'll need to switch to OS version 10.5 from 10.4
The version 10.5 allows REW and other Java applications to access the inputs of an external sound card (when set as the default in the sound preferences), but in 10.4, while the outputs of external sound cards can be accessed, the inputs cannot.
Old 09-03-09, 09:35 AM   #3
Alias: JC
User: #41476
Since: Sep 2009
Post Re: OSX and MOTU sound card
Thanks for the info! Unfortunately, that is not an option for this machine. It's my main music machine and
when everything works- it dont get changed for nothin!
No worries, I'll try another machine.
Thanks-
JC
« Home Theater Shack > Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards »
external soundcard, motu, osx
