| SPL Meters | Mic's | Calibration | Sound Cards What about the influence of your preamp/mixer??Discuss What about the influence of your preamp/mixer?? in the Equalization | Calibration forum; What about the influence of your preamp/mixer?? Last week, I got the SVS equalizer and was surprised as to the difference between what the predicted response with ... |
Views: 214 - Replies: 10
| What about the influence of your preamp/mixer?? Last week, I got the SVS equalizer and was surprised as to the difference between what the predicted response with the equalizer sofware was compared to what I'm getting with REW. This got me thinking about my REW setup. You know that we calibrate the sound card within REW. We also use calibration files for our microphones. But what about the preamp mixer?? how does that influence the test results? Unless I missed something, there is no way of knowing the influence of this device. I use the Behringer XENYX 802 Mic Preamp. It has all kinds of adjustments for the manipulation of highs mids and lows. They're on reostats and we know how those can break down. Is this really an area of concern? I've been thinking about getting the Galaxy CM-140 microphone primarily to help eliminate the clutter. Now I'm thinking it might would have the added benefit of having a calibration file that take into consideration the preamp function. | ||||
| | #2 | |||||||
| Re: What about the influence of your preamp/mixer?? Quote:
Regards, Wayne | |||||||
| | #3 | ||||
| Re: What about the influence of your preamp/mixer?? Hi Wayne..THANKS for responding. Its been quite a while since I did my original sound card calibration. I could have sworn the mixer wasn't in the loop, but I may very well be wrong. I'll go back and try to retrace my steps. As for sound cards with built in mic preamp and phantom power...can you make a recommendation. I'm currently using a Soundblaster live 24bit external USB. I'd prefer to stay USB as I'm using a laptop for this application. | ||||
| | #4 | ||||
| Re: What about the influence of your preamp/mixer?? Most of the soundcards with a mic input with phantom power are quite expensive. A popular one is the M-Audio Mobile Pre. brucek | ||||
| | #5 | ||||
| Re: What about the influence of your preamp/mixer?? I have the Mobile Pre. It is not without it's idiosyncrasies, but once you get the hang of dialing in the gains and levels, it is a good sound card. The built in phantom power was the main reason I got it. I use it with the ECM8k and even built a jig to check speaker impedances and resistor values with it. Their tech support is also very good. Whenever I have had an issue, they have responded very fast (and thoroughly). Good luck. | ||||
| | #6 | ||||
| Re: What about the influence of your preamp/mixer?? I'd rather have one that just works without any need to contact tech support. I'm leaning more toward that galaxy mic and keep using my soundblaster external usb sound card. My current issue is finding that xlr to rca adapter so I can at least run a new sound card correction file that includes my preamp/mixer in the signal chain. Its very aggrevating to know that you have it somewhere and just can't find it. | ||||
| | #7 | ||||
| Re: What about the influence of your preamp/mixer?? Well, the tech support calls I made were about specific gain values and input impedances. Stuff you won't find in the manual, but that I needed to know. Nothing was about the function of the unit. | ||||
| | #8 | ||||
| Re: What about the influence of your preamp/mixer?? So Anthony, as far as REW is concerned, was it pretty much "plug and play?" We've seen some of those sound cards have problems generating calibration files, etc. Regards, Wayne | ||||
| | #9 | ||||
| Re: What about the influence of your preamp/mixer?? The only problem with the calibration file was that there is no easy way to loop the XLR balanced to the tip-sleeve input (unbalanced). You can use an adapter, but then it's not an apples-to-apples calibration, since the adapter will force the card to use the XLR in unbalanced mode. This all being said, I just ran a 1/4" instrument cable from the tip-sleeve line out to the tip-sleeve line in and did the calibration that way. It is identical to the one I did by making an adapter cable. The only weird part of this sound card is the adjustable gains for the inputs. It adds an extra complexity to setup balancing system volume, input levels, and then the line-in/mic gains. But once you get the hang of it, you can set it up for new measurements almost automatically. | ||||
| | #10 | ||||||
| | #11 | |||||
| Bookmarks |
| Tags |
| influence, preamp/mixer?? |
| Thread Tools | |
