Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards
CSL-Calibrated EMM-6 Microphone Sale
Discuss CSL-Calibrated EMM-6 Microphone Sale in the Equalization | Calibration forum; CSL-Calibrated EMM-6 Microphone Sale Anechoic wrote: At what frequency? As you might imagine I'm hip deep in EMM-6s right now, but if I get ...
Views: 13960 - Replies: 191
Old 11-07-09, 01:25 PM   #176
Alias: melberi
User: #12290
Since: Oct 2007
  melberi is offline
Re: CSL-Calibrated EMM-6 Microphone Sale
Anechoic wrote: View Post
At what frequency? As you might imagine I'm hip deep in EMM-6s right now, but if I get a chance tonite, I'll run an output impedance sweep.
Posted via Mobile Device
500 Hz. My method was quick and dirty, I inserted a resistor of known resistance (~160 ohms) between the mic and preamp and comparing the voltage at preamp to the case without resistor. Input to microphone was provided by a headphone driver right next to mic and the measurement was repeated a few times (in addition to averaging over time in each case in ARTA).
I'd love to get confirmation of the result from a mic or two of yours!
Old 11-07-09, 06:47 PM   #177
Alias: BK
User: #43750
Since: Oct 2009
  BK_856er is offline
Received my calibrated EMM-6 in CA today - looks great!
Is the serial number a Dayton thing or a CSL creation? I don't see any markings on the mic.
Thanks again for the great service, Herb.
BK
Old 11-07-09, 08:58 PM   #178
Alias: Dennis H
User: #7943
Since: Apr 2007
  Dennis H is offline
I think the important thing about the output impedance is it doesn't affect the measured mic sensitivity much if at all. Herb did a check a couple of pages back and got essentially the same voltage reading out of the mic whether it was driving his high-impedance Sencore or his low-impedance Presonus. I'd say they're within the normal margin of error for such measurements using very different hardware and software and it's not something we need to concern ourselves with.
Sencore SP395: 6.995 mV (40K impedance)
Presonus Firebox: 6.981 mV (1.3K impedance)
Dennis H
Old 11-08-09, 03:21 AM   #179
Alias: melberi
User: #12290
Since: Oct 2007
  melberi is offline
I can't agree with that. The difference to open loop voltage grows to over 1.5 dB with a 300 ohm source and a 1500 ohm load. If someone is interested in a measured sensitivity value this is a significant difference. If accuracy wasn't a concern, using the manufacturer's stated sensitivity would be enough.
Old 11-08-09, 11:36 AM   #180
Alias: Dennis H
User: #7943
Since: Apr 2007
  Dennis H is offline
20*log(6.995/6.981) = .0174dB
Maybe, to put this to bed, Herb will have time to do an alternative test that doesn't depend on getting the ARTA calibration right. Plug a splitter cable into the mic, run one leg to the Sencore and measure the voltage. Then plug the other leg into the Presonus (with phantom power off) and see if the reading on the Sencore changes. As usual, I volunteer the mic I ordered to be Herb's test dummy as I'm in no rush to get it.
Edit: I don't know what preamp circuit the EMM6 is using but these mics are all designed to give an accurate voltage into a low-impedance load. For example, Earthworks specs a minimum of 600 ohms between pins 2 and 3.
http://www.earthworksaudio.com/26.html
Dennis H
Old 11-09-09, 08:05 PM   #181
Bronze Supporter
Alias: Anechoic
Loc: Springfield, MA
User: #32188
Since: Jan 2009
  Anechoic is offline
Quick & dirty EMM-6 output impedance measurement using the voltage divider method, a signal generator and an imedpance-matching potentiometer.
Old 11-09-09, 08:45 PM   #182
New Member
Alias: Noub
Loc: Madison, WI
User: #23792
Since: Aug 2008
  Noubourne is offline
My mic came today.
Ordered a MobilePre, an XLR cable and a pair of RCA-TS adapters.
I think I will be ready to test full-range once the stuff gets in!
Going to bug the out of my friends with this. HA!
Old 11-09-09, 09:10 PM   #183
Bronze Supporter
Alias: Anechoic
User: #32188
Since: Jan 2009
  Anechoic is offline
BK_856er wrote: View Post
BK
The serial number is mine, so I can keep track of the various mics for the inevitable screw-ups. I also have serial numbers for the Behringer mics - I started using my own S/N before Behringer started tagging their mikes.
Old 11-10-09, 12:23 AM   #184
Alias: BK
User: #43750
Since: Oct 2009
  BK_856er is offline
But if the SN is only on the paperwork and not on the mic itself....
I think I'll lightly etch the SN into the base of mine with a diamond-tip pen, just in case I end up with a collection of them some day.
BK
Old 11-10-09, 12:28 AM   #185
Bronze Supporter
Alias: Anechoic
User: #32188
Since: Jan 2009
  Anechoic is offline
BK
I actually bought stickers that I was going to use to stick the S/N to each mic but decided against it at the last minute because I didn't want to mar the mikes. Maybe next go-round, I'll include the sticker in the case and let the buyer make the choice.
Old 11-10-09, 12:51 AM   #186
Bronze Supporter
Alias: Anechoic
User: #32188
Since: Jan 2009
  Anechoic is offline
EMM-6 update: the last group of microphones has been packed, labeled and will be shipping out on Tuesday. I have four EMM-6 microphones left. Go get 'em!
After those are sold out, I'll put up a sign-up page for interest in another group-buy, and when I get a minimum number, we can do this again.
Old 11-10-09, 11:28 AM   #187
Alias: melberi
User: #12290
Since: Oct 2007
  melberi is offline
Thank you for this. I have to say I expected the impedance to be flatter, but I think the 300 ohms I came up with is a good average from that graph.
edit: I'm also interested in the distortion measurements. A near-field measurement of a 15" Dayton sub came up with ~19% second harmonic, ~119dB @ 50Hz.
Old 11-10-09, 09:59 PM   #188
Bronze Supporter
Alias: Anechoic
User: #32188
Since: Jan 2009
  Anechoic is offline
melberi wrote: View Post
That result does seem rather... odd, doesn't it? I think it may be caused by my "quick and dirty" method. I did another impedance method with slightly more rigor (and a different mic):
That's more in line with what I would have expected, but still higher than 200 ohms.
Old 11-18-09, 03:25 PM   #189
Bronze Supporter
Alias: Anechoic
User: #32188
Since: Jan 2009
  Anechoic is offline
Well the holidays are almost upon us. I implied in the other CSL thread that I was considering offering a Black Friday special. Given that I'm a handful of names away from pulling the trigger on another EMM-6 group buy, I figured I would combine the existing discount with another offer.
As always, HTS members will get $5 off.
Everyone (including HTS members) will also get $9 off the order. That basically means free shipping for domestic orders of 1 mic and discounted shipping for international orders.
There is a limit for this offer however - it will apply to the first 25 orders only.
I'm still at the sign-up stage, but when I get enough interest in the group up, I'll put up the order page and I expect to start shipping mics within 3 days of closing the order page.
EDIT: belay that post - it turns out PE is sold out of EMM-6's and won't get anymore until January. I'm going to see if I can get s deal on ECM8000's from them or another supplier.
Old 11-19-09, 02:34 AM   #190
Alias: tnargs
Loc: Australia
User: #2459
Since: Sep 2006
  tnargs is offline
Just checking, does this mean the group buy is on hold? I was about to put my name down.
Old 11-19-09, 10:50 AM   #191
Bronze Supporter
Alias: Anechoic
User: #32188
Since: Jan 2009
  Anechoic is offline
tnargs wrote: View Post
Well EMM-6 groups buys are obviously on hold until January, but I am trying to set up a group buy for ECM8000 right now. If you're interested in the ECM8000 for that price (plus discounted shipping), by all means sign up!
Old 11-19-09, 05:10 PM   #192
Bronze Supporter
Alias: Anechoic
User: #32188
Since: Jan 2009
  Anechoic is offline
Bad news: I can't get a deal for ECM8000s.
Good news: I may be able to start selling calibrated ECM8000-type mics for *significantly * less than what I've been selling the Dayton's for. Stay tuned.
« Home Theater Shack > Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards »
csl-calibrated, emm-6, microphone, sale
