Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards
Pre amp to boost mic signal?
Discuss Pre amp to boost mic signal? in the Equalization | Calibration forum; Pre amp to boost mic signal? I have a calibrated dbx rta-m microphone that I want to use with my laptop and REW. I have a ...
Views: 241 - Replies: 2
Old 09-22-09, 06:22 PM   #1
Alias: Darryn
Loc: Snohomish, WA
User: #1517
  seattle_ice is offline
I have a Turtle Beach external USB card and a 48V phantom power adaptor. After a couple hours of trying to get the input signal high enough to work, I gave up in frustration.
My question is this: Is there enough difference in the sensitivity of various mics that a pre-amp is necessary? Not just the phantom power, but an actual pre-amp that can boost the gain.
If the women don't find you handsome, they should at least find you handy - Red Green
My Theater Build
Old 09-22-09, 08:40 PM   #2
Alias: brucek
User: #6
  brucek is online now
Re: Pre amp to boost mic signal?
You always require a preamp for a condenser mic to raise the signal to line level. They aren't meant to be plugged directly into line level circuits.
Most people here use the Behringer XENXY802. There are certainly others though...
Old 09-22-09, 09:42 PM   #3
Alias: Darryn
Loc: Snohomish, WA
User: #1517
Aha. Well, that does explain it. I don't know why that didn't click for me. I have used pro audio equipment for 30 years, and I think I have read nearly every thread here over the last two years. Just didn't dawn on me until now.
Thanks
My Theater Build
« Home Theater Shack > Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards »
boost, signal?
