| SPL Meters | Mic's | Calibration | Sound Cards Soundcard Calibration Question?Discuss Soundcard Calibration Question? in the Equalization | Calibration forum; Soundcard Calibration Question? Is it correct that when using the optional loopback cable for the left channel and checking the appropriate box in ... |
Views: 172 - Replies: 3
| Soundcard Calibration Question? Is it correct that when using the optional loopback cable for the left channel and checking the appropriate box in REW to use left channel as calibration reference allows me to not be required to perform a soundcard calibration? Just want to be sure. Thanks | ||||
| | #2 | ||||
| Re: Soundcard Calibration Question? Yes, that's correct, but it's advisable to not go that route. It's easier to create a one-time soundcard calibration file and then remove the loopback cable and then use that channel for your measurements. The left channel as cal reference method is usually reserved for performing distance checks. brucek | ||||
| | #3 | ||||
| Re: Soundcard Calibration Question? Thanks brucek, I initially tried to calibrate the card, but ran into some problems. Will try again at a later date. Right now I'm having too much fun equalising my mains with the DEQ2496. They were pretty flat without any adjustments and sounded good. Now with minimal eq correction they sound just incredible. | ||||
| | #4 | |||||
| Re: Soundcard Calibration Question? Quote:
brucek | |||||
| Bookmarks |
| Tags |
| calibration, question?, soundcard |
| Thread Tools | |
