| SPL Meters | Mic's | Calibration | Sound Cards Windows PC based room EQ systemDiscuss Windows PC based room EQ system in the Equalization | Calibration forum; Windows PC based room EQ system Is there a Windows-equivalent of the Sonic Studio Amarra? This product combines EQ measurement and an outboard sound subsystem, although ... |
Views: 297 - Replies: 5
| Windows PC based room EQ system Is there a Windows-equivalent of the Sonic Studio Amarra? This product combines EQ measurement and an outboard sound subsystem, although it appears to be Apple only. Ideally, I could plug a microphone into an XLR socket of my existing M-Audio FW 410 preamp/DAC (connected to an HP HDX laptop via Fire Wire) and the software would make the room acoustics measurements, and then apply appropriate equalization settings to the digital bit stream on its way from the PC out to the FW 410. My application is strictly two channel audio, with the FW analog outputs driving a pair of self-powered KRK Rokit 8 speakers. From my initial look at the REW material, it seems to be primarily addressing internal sound boards, although the REW may be doing exactly what I'm looking for. So, a little guidance from more experienced people will be most appreciate ![]() Nicholas Bedworth, CTO DigitalDirect Development Corporation | ||||
| | #2 | ||||
| Re: Windows PC based room EQ system REW can address most any soundcard - internal or external. I'm not sure what your question is? Are you looking for filters to use with a convolver? brucek | ||||
| | #3 | ||||
| Re: Windows PC based room EQ system Hi Bruce, Basically does REW apply equalization settings to the output digital stream going to the internal/external sound card? In other words, assuming REW deterimes the EQ required to normalize room acoustics, where (in what device) is this EQ being applied? Or is REW simply a passive measurement system, which shows you what needs to be done, and then you have to apply the EQ manually through either equalizer software, or adjusting equalizer settings in a device? Nick | ||||
| | #4 | |||||
| Re: Windows PC based room EQ system Quote:
REW has the ability to export the filters impulse response as a wav file that can be used in PC based convolvers that apply that filtering to the signal leaving the soundcard (HTPC's). brucek | |||||
| | #5 | ||||
| Re: Windows PC based room EQ system This is very helpful. Thanks! Now, how about some recommendations for 1. PC-based convolvers and 2. Midi-capable external equalizers? My M-Audio FW 410 has Midi. Nick | ||||
| | #6 | ||||
| Re: Windows PC based room EQ system I know little to nothing about convolvers I'm afraid, other than what I read in our convolver thread. All the Behringer equalizers have midi connections and so do M-Audio and other external soundcards, but the equalizers that are usable with REW for automatic filter transfer are very few (DSP1120P, DSP1124P, FBQ2496, SMS-1, R-DES). I find it faster to just enter the filters by hand though.... brucek | ||||
