| SPL Meters | Mic's | Calibration | Sound Cards Loopback cable for Tascam 144Discuss Loopback cable for Tascam 144 in the Equalization | Calibration forum; Loopback cable for Tascam 144 Hi
I just bought Tascam 144, Behringer ECM8000 mic and XENYX 802 console/pre-amp.
However, I did not understand which cable ... |
Views: 140 - Replies: 11
| Hi I just bought Tascam 144, Behringer ECM8000 mic and XENYX 802 console/pre-amp. However, I did not understand which cable I need for the loopback connection. As I understood, the input is BALANCED TRS 1/4" and the output is UNBALANCED RCA, right? But I could not find an appropriate cable at B&H. Moreover, the guy over there yesterday give me TRS 1/4" to TRS 1/4" cable, convincing me that what's I need.. Am I missing something? ![]() | ||||
| | #2 | |||||
| Re: Loopback cable for Tascam 144 Welcome to the Forum, Michael! Did you keep your receipts? The Tascam has a mic pre amp and phantom power, so you don't need the Xenyx. Also, you don't need the ECM8000 unless you want to do full-range measurements (i.e., the subs and main speakers). If you're only wanting to take measurements of your sub, then the Radio Shack SPL meter is all you need. Quote:
The cable will loop between the left 1/4" input and left RCA output (actually, it doesn't matter which one you use, but I think the REW help files and diagrams suggest using the left). Regards, Wayne | |||||
| | #3 | ||||
| Re: Loopback cable for Tascam 144 :-( I have the receipts, but I threw out the packaging. Anyway, 45$ is not a big deal. I read few threads and I understood that this is what people here are using hence I bought the mic together with 802. Moving forward.. yes, Tascam has only RCA unbalanced (e.g. plain bananas) plugs, right? So, I need RCA unbalanced to TRS ¼" balanced cable? Does it exist? I have absolutely zero knowledge with the PRO equipment.. | ||||
| | #4 | |||||
| Re: Loopback cable for Tascam 144 No, not TRS. Quote:
Wayne | |||||
| | #5 | ||||
| Re: Loopback cable for Tascam 144 Hi Wayne Sorry for being slow, but I will understand eventually.. is this what I need? http://www.bhphotovideo.com/c/produc...h_TS_1_4_.html Are these cables bi-directional or direction IS important here? | ||||
| | #6 | |||||
| Re: Loopback cable for Tascam 144 The description of the cable I brought above says.. Quote:
| | #7 | |||||
| Re: Loopback cable for Tascam 144 No problem! No one is born an expert, we all had to learn, too. ![]() Quote:
No directionality does not matter. Regards, Wayne | |||||
| | #8 | |||||
| Re: Loopback cable for Tascam 144 Quote:
![]() Regards, Wayne | |||||
| | #11 | ||||
| Re: Loopback cable for Tascam 144 There is a spinning control dial (looks like volume) on the Tascam itself, saying "LINE" where is supposed to be ZERO and "MIC" where supposed to be MAX. Shall I change it to "LINE"? | ||||
| | #12 | |||||||
Regards, Wayne A. Pflughaupt | |||||||
