| SPL Meters | Mic's | Calibration | Sound Cards Calibration of a TASCAM US122LDiscuss Calibration of a TASCAM US122L in the Equalization | Calibration forum; Calibration of a TASCAM US122L Dear all,
I would like to calibrate my USB soundcard TASCAM US 122 L. I am running some laboratory experiments ... |
Views: 108 - Replies: 3
| Calibration of a TASCAM US122L Dear all, I would like to calibrate my USB soundcard TASCAM US 122 L. I am running some laboratory experiments where I use two AKG CK77WR plugged into the TASCAM. While the mikes have been calibrated and their sensitivity and frequency response is known, I would also need to measure the response of the sound card. I understand that the REW software can be used for this purpose. I have read the on-line manual etc. Everything about how to use the software is very clear. However, I would need some sort of tutorial on how to setup connections, the type of cables that I will need, etc ... My apologies if this sounds quite basic for many of you. I am really new to sound measurements and still have a lot to learn. Hope that someone can point me in the right direction. Thank you for your help. Silvio | ||||
| | #2 | |||||
| Re: Calibration of a TASCAM US122L Quote:
brucek | |||||
| | #3 | ||||
| Re: Calibration of a TASCAM US122L The Help files have a section on sound card calibration. In addition, there are step-by-step instructions in the REW program during calibration. Here is a thread with some details in the Tascam 144, which is identical to the 122 only with a firewire connection added. If all else fails, the 122 doesn't really need a calibration file. It's down only .5 dB at 10 Hz, and up about .25 dB near 20 kHz. IOW, it's essentially ruler flat out of the box. This graph shows a 144 calibration file another Member generated (dotted line). ![]() Regards, Wayne | ||||
| Bookmarks |
| Tags |
| calibration, tascam, us122l |
| Thread Tools | |
