Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards
RS SPL orientation - horizontal or vertical
Discuss RS SPL orientation - horizontal or vertical in the Equalization | Calibration forum; RS SPL orientation - horizontal or vertical Can't find any refernece to this, but should the RS SPL be mounted vertically or horizontally, and if horizontal should ...
Views: 911 - Replies: 1
Old 09-09-07, 01:17 PM   #1
mortod
Inactive
Alias:
User: #
Posts: n/a
Can't find any refernece to this, but should the RS SPL be mounted vertically or horizontally, and if horizontal should it be pointed at the speaker or at the centre point between speakers. I guess the question really is - what orientation was used for the RS SPL callibration testing?
Old 09-09-07, 01:36 PM   #2
Friend of the Shack
Alias: Otto
Otto's Avatar
Loc: Beautiful Colorado
User: #625
  Otto is offline
Re: RS SPL orientation - horizontal or vertical
Hi mortod, and welcome to the Shack!
Just point the thing vertically (straight up) at the listening position.
Good luck!
-- Otto
« Home Theater Shack > Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards »
