| SPL Meters | Mic's | Calibration | Sound Cards What are my mic options?Discuss What are my mic options? in the Equalization | Calibration forum; What are my mic options? I downloaded Room EQ Wizard. I am using a MacBook with parallels installed (XP) and want to know what are ... |
Views: 831 - Replies: 2
| | #2 | |||||
| Re: What are my mic options? Quote:
With regard to laptops, generally they have mic inputs rather than the required line-in plug that REW requires, so you may require an external USB soundcard. Most users with laptops use external soundcards. They're fairly inexpensive. brucek | |||||
| | #3 | ||||
| Re: What are my mic options? If you don't have a db meter you'll need one. This I brought up because the Galaxy decibel meter can also be used as a microphone. Being as I own a db meter I am buying the Behringer ECM 8000, you need a microphone pre with the ECM 8000 if using the 1124. Go to the downloads page and you can download calibration files for both pieces. These .cal files load right into REW. Portland, Oregon | ||||
