Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards
Which external sound card do you recommend?
Discuss Which external sound card do you recommend? in the Equalization | Calibration forum; Which external sound card do you recommend? I need to use BFD, REW and SPL for equalising my sub. Since i only have a laptop that doesnt ...
Views: 973 - Replies: 9
Old 12-25-07, 07:20 PM   #1
P-P-S-S
Inactive
Alias:
User: #
Posts: n/a
I need to use BFD, REW and SPL for equalising my sub. Since i only have a laptop that doesnt have the necessary connections i need to get an external soundcard. Which one do you guys reccomend? So far i have had a look at Creative SoundBlaster Live 24bit external and the Sound Blaster Audigy 2NX but am not sure which one to get?
Any advice would be highly appreciated. Thank you in advance.
Old 12-25-07, 07:22 PM   #2
Alias: Andrew
avaserfi's Avatar
Loc: College Station, TX
User: #9992
Since: Jul 2007
  avaserfi is offline
Re: Which external sound card do you recommend?
I picked up the Soundblaster Live 24bit for my external a while ago and it works perfectly with REW. Nice and cheap as well as effective. I see no reason not to get it .
Old 12-25-07, 07:41 PM   #3
P-P-S-S
Inactive
Alias:
User: #
Posts: n/a
Andrew does it have all the ports to connect SPL, receiver, etc? (i think it dont have midi in and out but that's not important since i have bought a separate USB to MIDI adaptor) I am not very knowledgable in this field (i have just started) so excuse all my questions.
Old 12-25-07, 07:53 PM   #4
Alias: Andrew
avaserfi's Avatar
User: #9992
Since: Jul 2007
  avaserfi is offline
Yup, the Soundblaster has all needed outputs and inputs to work with everything - although you will need some adapters. If you go to the REW help file and choose "Getting Started with REW" then click "Soundcard Connections" you will see images of the setup protocol which is fairly straight forward.
The REW help file is probably the best and easiest I have ever come across plus you get free tech support at this site .
Old 02-21-08, 08:39 PM   #5
New Member
Alias: Rutgers1
Loc: Nesconset, NY
User: #16580
Since: Feb 2008
  Rutgers1 is offline
Is there a preference for a MIDI? I found this one for $30.00 on the web.
E-MU EM8780 Professional USB Bus powered Midi Interface with 1 in 1 out and Midi Status Indicator Lights.
Old 02-21-08, 10:10 PM   #6
Alias: brucek
User: #6
  brucek is online now
I think the one I see most people using is the Edirol UM-1EX
Old 02-22-08, 12:21 PM   #7
New Member
Alias: Rutgers1
Loc: Nesconset, NY
User: #16580
Since: Feb 2008
  Rutgers1 is offline
brucek wrote: View Post
Thanks Bruce. I just visited their website and read that this product is compatible with Vista, but not the 64-bit Edition of Windows Vista. My laptop came with Vista Home Prenium. I not computer savvy at all and would not know if my edition is the 32 or 64 bit edition. How can I find out what edition I have?
Old 02-22-08, 03:44 PM   #8
Alias: brucek
User: #6
My laptop came with Vista Home Premium. I not computer savvy at all and would not know if my edition is the 32 or 64 bit edition. How can I find out what edition I have?
1. Click Start, type system in the Start Search box, and then click System or System Information (depending on your system) in the Programs list.
2. The operating system appears as follows:
• For a 64-bit version operating system: 64-bit Operating System appears for the System type under System.
• For a 32-bit version operating system: 32-bit Operating System appears for the System type under System.
Old 02-23-08, 03:07 PM   #9
New Member
Alias: Rutgers1
Loc: Nesconset, NY
User: #16580
Since: Feb 2008
  Rutgers1 is offline
Thanks Bruce! I do in fact have 32-bit system, so the card will be compatible.
« Home Theater Shack > Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards »
