Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards
Is this preamp OK?
Discuss Is this preamp OK? in the Equalization | Calibration forum; Is this preamp OK? Hi Is the Behringer TUBE ULTRAGAIN MIC100 Preamp preamp OK with the ECM8000? I can get one at a very ...
Views: 866 - Replies: 7
Old 01-05-08, 07:35 AM   #1
JulianC4
Inactive
Alias:
User: #
Posts: n/a
Is this preamp OK?
Hi
I can get one at a very reasonable price.
Regards JC4
Old 01-05-08, 08:21 AM   #2
Alias: brucek
User: #6
  brucek is online now
Re: Is this preamp OK?
Well, if you look at the specs it reads:
It features a carefully selected 12AX7 vacuum tube with UTC technology for exceptional warmth and lowest noise. Thus, the MIC100 can be used to eliminate the "dull" sound of standard digital recorders and sound cards. Also, it perfectly complements studio-grade condenser microphones. Dedicated Low Cut filter eliminates unwanted noise, e.g. floor rumble. .
All this verbiage really means is that it has anything but a flat response that you would require for a piece of test equipment to measure a room using REW. The HPF look undefeatable, so your bottom end would be cut off; which may render it uncompensatable if attempting to include the preamp in the soundcard cal file.
You'd be better off with a solid state preamp that enjoys a flat response...
Old 02-07-08, 05:28 PM   #3
Alias: jer
jeremy7's Avatar
Loc: ct
User: #16574
Since: Feb 2008
  jeremy7 is offline
I just bought that same preamp for use with my ecm8000. i guess ill try to return it. any suggestions on a solid state pre amp with flat response?
thanks
Old 02-07-08, 06:20 PM   #4
Alias: brucek
User: #6
Yes, the preamp we recommend is the XENYX 802
Old 02-07-08, 06:42 PM   #5
Alias: jer
jeremy7's Avatar
Loc: ct
User: #16574
Since: Feb 2008
  jeremy7 is offline
thanks brucek
Old 05-03-08, 04:45 AM   #6
JMRaudio
Inactive
Alias:
User: #
Posts: n/a
We need just one microphone input, why not consider the XENYX 502 only ?
Old 05-03-08, 07:56 AM   #7
Alias: brucek
User: #6
No phantom voltage feature.................
Old 05-04-08, 06:27 PM   #8
JMRaudio
Inactive
Alias:
User: #
Posts: n/a
Thanks a lot !... I didn't see there is no phantom voltage,
... and no input gain trim !
« Home Theater Shack > Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards »
