| SPL Meters | Mic's | Calibration | Sound Cards Mic and SPL calibrationsDiscuss Mic and SPL calibrations in the Equalization | Calibration forum; Mic and SPL calibrations I had to give up the ECM8000 I was using, we needed in the studio (it will be replaced soon) ... |
Views: 622 - Replies: 2
| Mic and SPL calibrations I had to give up the ECM8000 I was using, we needed in the studio (it will be replaced soon) and have to rely on the RS SPL meter. Is it okay to have both the mic and spl calibration on file or should I delete the mic calibration? Tom Daugherty | ||||
| | #2 | |||||
| Re: Mic and SPL calibrations Quote:
| | #3 | ||||
| Re: Mic and SPL calibrations As bruce wrote, Rew uses the calibration file(s) that you choose to use. If you take a look at the settings (in the Settings menu) then you will see that you can choose one calibration file for your sound card and one for your Mic/Meter. You probably already have calibrated your sound card so you don't need to change this file. But in the Mic/Meter section you can change the calibration file. Search the forum to discover which calibration file you need (there's one file per RadioShack model) and you're done ![]() Be aware that the RadioShack are not as accurate as the ECM8000, especially over 5KHz. Klipsch (THX2) | Crown | SVS | SlimDevices | Sony | Pioneer | Yamaha | ||||
