| SPL Meters | Mic's | Calibration EM-U 0404 USB CalibrationDiscuss EM-U 0404 USB Calibration in the Subwoofer Equalization | Calibration forum; EM-U 0404 USB Calibration I just bought an EM-U 0404 USB sound card and I'm trying to calibrate it.
Does someone have a calibration ... |
| | #1 (Link) | |||
| EM-U 0404 USB Calibration I just bought an EM-U 0404 USB sound card and I'm trying to calibrate it. Does someone have a calibration file that I could use to check against my results? Also: how did you calibrate your unit and which results (levels) did you obtain? I'm thinking of using a simple loop from my main out to the Mic/Hi-Z/Line A input. Martin Logan Vista | Swans F1.1C | SVS PC-Ultra | SlimDevices Transporter | Bladelius Tyr | Yamaha RX-V1800 | Denon DVD-2930 | Klipsch RS-52 | Sharp XV-Z3000 | Adeo Greyvision Plano 16:9 100" | |||
| | #2 (Link) | |||
| Re: EM-U 0404 USB Calibration I attach the calibration file I got from my results. Maybe someone could check it against his/her own setup and cal file? usb0404cal.jpg Note: I know that the x limits are incorrect but I want to show the entire curve. For info, the levels are: 1) Main output: between 11 and 12 (o'clock) 2) A Line input: around 2 o'clock Martin Logan Vista | Swans F1.1C | SVS PC-Ultra | SlimDevices Transporter | Bladelius Tyr | Yamaha RX-V1800 | Denon DVD-2930 | Klipsch RS-52 | Sharp XV-Z3000 | Adeo Greyvision Plano 16:9 100" | |||
| | #3 (Link) | ||||
| Re: EM-U 0404 USB Calibration Quote:
![]() After soundcard calibration, you leave the short loopback cable connected from line-out to line-in and do a full range measure of the cable (with the new soundcard cal loaded and no microphone cal loaded). The result will of course be a perfect flat line (if your soundcard cal is correct). brucek | ||||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| E-Mu 0404 USB with Phantom Power for ECM8000 | Stealthlude | SPL Meters | Mic's | Calibration | 8 | 04-27-08 01:01 PM |
| should i calibrate the ecm8000 or use the calibration file | jeremy7 | SPL Meters | Mic's | Calibration | 3 | 02-08-08 07:11 AM |
| C-weighting and calibration file questions | stokasz | REW Forum | 2 | 01-29-08 04:28 PM |
| Calibration file AND c-weighted box? | cnjvh | REW Forum | 2 | 01-31-07 10:26 PM |
| TES model 1350A calibration file wanted | goldeneye243 | SPL Meters | Mic's | Calibration | 0 | 10-01-06 03:48 AM |
