Mic phantom power - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Subwoofer Equalization | Calibration > SPL Meters | Mic's | Calibration
Mic phantom power
Discuss Mic phantom power in the Subwoofer Equalization | Calibration forum; Mic phantom power Hey guys, This is a great site, way over my head at the moment. The question i have is: i ...
Old 03-24-08, 01:07 AM   #1 (Link)
Alias: Boris
Loc: Penrith, NSW Australia
BOR15's Avatar
User: #18246
Since: Mar 2008
BOR15 is offline
Cool Mic phantom power
Hey guys,
The question i have is: i want to power a behringer ecm8000. Everyone here uses the behringer xenyx 802.
What is the advantage of this over say just a 48v phantom mic module?
i will leave my questions at that at the moment.
Thanks guys
Boris
Old 03-24-08, 01:49 AM   #2 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
Re: Mic phantom power
Hi Boris,
Anything with a phantom-powered mic pre-amp that boosts the signal to line level so that it would be suitable for a USB sound card can be used.
Old 03-24-08, 03:04 PM   #3 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
tonyvdb is online now
The advantage to using a phantom powered mic is that they are generally more sensitive and thus make a better mic for picking up wider dynamics in audio. Some have a battery installed right in the base of the mic where others require the voltage sent to it over the XLR mic cable from a mixer or other external power source.
The 48v signal is not always what the mic uses as this signal is the maximum that the sound board will send some mic's only need 1.5 volts.
Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2,
2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25,
2 Audio control C131 EQ's, Toshiba HD AX2 & Samsung BDP1400 DVD players, Sanyo Z2 projector
Two Channel system: Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub
Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer,
LG DV7832NXC DVD player, Motorola HD-PVR,
Sony KP-53HS30 rear projection HDTV, turntable PS-T20
Nintendo Wii
Old 03-25-08, 11:10 PM   #4 (Link)
Alias: Boris
BOR15's Avatar
User: #18246
Since: Mar 2008
BOR15 is offline
Thanks for the help guys.
I got the behringer .. only cost me AUS$85 ... SB Live 24 usb was only AUS$55 ... so not a bad deal at all
Boris
« Home Theater Shack > Subwoofer Equalization | Calibration > SPL Meters | Mic's | Calibration »
Similar Threads
Best USB sound and midi module including Phantom mic input ! imbeaujp SPL Meters | Mic's | Calibration 53 04-28-08 07:24 AM
E-Mu 0404 USB with Phantom Power for ECM8000 Stealthlude SPL Meters | Mic's | Calibration 8 04-27-08 01:01 PM
MIC in chambers1517 REW Forum 1 02-01-08 10:14 AM
Mic arande2 REW Forum 4 11-27-07 11:08 PM
Can I use this Mic? ROBSCIX REW Forum 9 04-01-07 05:08 PM
Mach 5 Audio
