what settings to use on the begringer mic800 preamp - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Subwoofer Equalization | Calibration > SPL Meters | Mic's | Calibration
Discuss what settings to use on the begringer mic800 preamp in the Subwoofer Equalization | Calibration forum; what settings to use on the begringer mic800 preamp I guys/gals i had my first try out with said equipment s/b card live24/ B ecm8000 mic/ B mic800 , ...
Old 03-27-08, 05:52 AM   #1 (Link)
Alias: stephen
Loc: England
User: #16723
Since: Feb 2008
mojogoes is offline
I guys/gals i had my first try out with said equipment s/b card live24/ B ecm8000 mic/ B mic800 , i only wanted to connect to the sub and take some reading which i never actually did because 1/ i wasn't sure if after extensive reading if i had the connections setup right (but i'm sure it was) 2nd/ i wasn't sure what settings the preamp needed to be in to get the correct out come.....does the v48 phantom need to be lit and although i've read the manuals they don't correspond to what we need to some degree.
Ps on the S/B live24 which connection is the line out to connect for a loopback into the line in , i was using one of the Right speaker connection and feel this was wrong.Doh.
Doh.......obviously phantom has to be set as on for the mic.....my apologies.
Old 03-27-08, 09:44 AM   #2 (Link)
Alias: brucek
User: #6
brucek is online now
Re: what settings to use on the begringer mic800 preamp
Read this thread with regard to the 800 preamp.
Here's a sticky with regard to connecting up REW.
« Home Theater Shack > Subwoofer Equalization | Calibration > SPL Meters | Mic's | Calibration »
Similar Threads
Bfd , Ecm8000 , B Mic800 pre-amp , G-star 5.1 soundcard whats next please. mojogoes BFD Forum 12 02-23-08 01:26 PM
What are your HT-S894 settings? bobh33 System Setup and Connection 1 02-12-08 02:08 PM
How to adujst EQ settings devicente Home Theater Components 2 11-14-07 06:48 PM
display settings scott Home Theater Projectors 2 01-15-07 02:49 PM
subwoofer settings evan BFD Forum 2 04-20-06 08:13 AM
Mach 5 Audio
